Fuel Sending Unit
Old Oct 29, 2013 | 02:02 PM
1987_XLT_Lariat_F250's Avatar
Fuel Sending Unit
Hello everyone, I'm new to the site but I really like it and plan to use it a lot.
So I have a carbureted 1987 F250 and I'm having issues with what I beleive is my fuel sending unit. My gas gauge always reads past full, and it starts to move around and then reads a 1/4 tank when it is seemingly empty. I have read around and I think it may be the ground wire to the sending unit but I am unsure. I got this truck from my grandfather for my 18th birthday and I have rebuilt it, got another carb, and made it a daily driver since. If anyone has some tips like checking the resistance in the wires and checking the ground itself, it would help me alot. I dont have a diagram in my Haynes manual that shows where the ground to the fuel sending unit is located.
Thanks!
Old Oct 29, 2013 | 03:06 PM
subford's Avatar
subford
This problem is caused by a coating on the resistance element of the fuel sender and may clear up on its own in time if you use it for a daily driver.
Does this truck have a 460 engine in it?
Old Oct 29, 2013 | 03:29 PM
Well its always been that way on the truck. Im not experienced enough to find the wire haha and it has a 351 windsor in it.
Old Oct 29, 2013 | 04:13 PM
subford's Avatar
subford
This diagram may be close if it has a 460 in it:
Old Oct 29, 2013 | 04:46 PM
kermmydog's Avatar
kermmydog
I had an 86 F250 4x4 with a 460 & the only way I was able to fix the same exact problem was to replace the pump unit. As I remember back then (in the 90s) they were only available through Ford & sold as a complete unit, (pump & sending unit.) so if you can buy then separate or not today I don't know. But either way the tank must come out.
Old Oct 29, 2013 | 06:34 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Or the bed comes off.
Pick your poison.
Old Oct 29, 2013 | 06:38 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
Pick your poison.
Now that part I don't like
That is the diagram I need for Mine,will help Me out
Old Oct 29, 2013 | 06:41 PM
78 & 87 Super Cab
Thanks!
Welcome to FTE! I also have a 1987 F250 XLT Lariat Super Cab, Mine has the carbed 460. And My gauge is like yours, except it never moves away from full, it goes farther past it when key is on.
Aaron-71
Aug 19, 2010 05:41 PM
Hunt4Fun
Nov 12, 2008 03:07 PM
boggerted
Oct 29, 2007 07:43 PM
sailboat2323
Electrical Systems/Wiring
Aug 29, 2004 04:43 PM
bscott00
Jun 27, 2003 11:52 AM
