It might be good to verify the up pipes to the turbo are not leaking first - any soot around the up pipes where they connect to the turbo or on the firewall? A boost leak check would be good as well. Search for "boost leak detector" for good info. Is the air filter clean? What type of filter are you running?
You may be able to rebuild it and save yourself some money. Depends n what is wrong with it. Pull your intake off and see what your intake wheeel looks like. Check and see if it spins freely, if there is any side to side movement of the shaft(bad).
