Axel Seals (front)
Old Oct 28, 2013 | 05:17 AM
adammdennis11's Avatar
adammdennis11
Axel Seals (front)
Both of my Axel seals up front appear to have popped out. What causes this ? Is it hard to fix?
Sent from my DROID BIONIC using IB AutoGroup
Old Oct 28, 2013 | 07:01 AM
CPB1's Avatar
CPB1
What year truck?
Old Oct 28, 2013 | 07:05 AM
adammdennis11
2006
Old Oct 28, 2013 | 08:58 AM
CPB1's Avatar
CPB1
Is this the seal?
I put these updated seals in my 05 F250 when I was doing ball joints, so far so good.
You need to remove: Hub, brake caliper, caliper mount, rotor, hub/bearing unit, and axle.
Hardest part IMO is removing the snap ring, you will need a good pair of snap ring pliers. You will also need to remove and install the knuckle seal. There is a tool for installing it back correctly.
Old Oct 28, 2013 | 09:06 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Pretty common problem. Here's another thread on the subject.
https://www.ford-trucks.com/forums/1...repairing.html
Old Oct 28, 2013 | 10:19 AM
adammdennis11
Found out it is the dust seals, cleaning them and popping them back in might work, but I read it is a common issue..
Old Oct 28, 2013 | 10:21 AM
adammdennis11
Thank you guys for the help.
Old Oct 28, 2013 | 11:34 AM
POORBOY1964's Avatar
POORBOY1964
Worth a try you have to take off and replace so much to get there.
Old Oct 28, 2013 | 12:48 PM
adammdennis11
Yeah, that's what I hear, I'll probably let them dangle for now, I don't go mudding or into water so they should be fine...
Old Oct 29, 2013 | 06:12 AM
Iron2's Avatar
Iron2
Here is the part number for the updated seals, I replace the originals once, it was a waste of time. No problems with the updated ones.
AC3Z-1S175-A (BRS-170)
Old Oct 29, 2013 | 07:44 AM
Donzi Dude's Avatar
Donzi Dude
my sons and mine are both popped out, I know 4 guys that have 6.0s and they are also all popped out.
Old Oct 29, 2013 | 10:21 AM
rotun's Avatar
rotun
Reads ***** rules!
I have replaced mine once per year, even the updated ones. Poor design, but I also run 4wd in January's freezing temps and that's when they seem to come apart. I've even greased the inside perimeter and contact area on the shaft and it still happens.......I've just made them part of my regular spring cleaning.
Old Oct 29, 2013 | 10:23 AM
MisterCMK's Avatar
MisterCMK
You have issues with the ones that pound into the axle tube?
Did you clean the axle shaft when you installed them?
These are the humble words of MisterCMK sent on the go...
Old Oct 29, 2013 | 10:48 AM
rotun's Avatar
rotun
Reads ***** rules!
Had the dealer do it the first few times when it was covered under warranty, now I do it myself. Yes I clean the axle shaft and give the inside of the tubes a bath in FluidFilm. We have seen 20 and 30 below 0 during our 2 week hunting season, breaking trail in 4'+ deep snow it just tears those seals up. Douching the whole undercarriage with FluidFilm seems to help prolong but the ice buildup still has its downfall, rubber doesn't like to move with it being that cold.
Old Oct 29, 2013 | 11:26 AM
rotun's Avatar
rotun
Reads ***** rules!
Just getting started............
Jowen1017
Mar 17, 2014 09:19 PM
Linne
Sep 7, 2013 06:32 AM
Fullcrew7.3
Jun 27, 2011 09:17 AM
KoolAidMan888
Mar 12, 2011 08:30 PM
RA81222
1978 - 1996 Big Bronco
Apr 26, 2006 08:52 PM
