Sponsored by: Real Truck
D50 dust seals?
Old May 5, 2013 | 02:14 PM
Linne's Avatar
Linne
D50 dust seals?
Hi,
I am trying to find new inner and outer axletube seals for my D50 and I think they are both the same in D50 and D60...
Is this one the outer dust seal? Dana Spicer Part 50491 - Dana 60 Spindle Seal
And why is it named spindle seal?
Old May 7, 2013 | 08:57 PM
vortec 1's Avatar
vortec 1
Yes those are the correct outer seal's.I know them as axel shaft seals.You also need a special tool to press the inter and outer seals on.I just bought the tool last week.I have not used it as of yet but See attachment!!
Ford Axle Shaft Seal Installer - Unique Truck Equipment
Old May 8, 2013 | 01:02 PM
joeycyph56's Avatar
joeycyph56
how hard is it to replace that seal?..thanks
Old May 8, 2013 | 01:57 PM
vortec 1's Avatar
vortec 1
You have to pull the Hub, which is held on by an outer ring you compress and remove with needle nose pliers .Then remove caliper, brake pads, and rotor. Then pull the spindle which has a big snap ring and a hex washer and three other washers. Make sure to put the washers back on in the same order. Once the hub is pulled, take a pry bar and pry on the joint area of the axle shaft and the axle pops out of the housing. Then you can remove the seals and install the new ones.
Old Sep 3, 2013 | 03:50 AM
Linne's Avatar
Linne
Last week end I installed my new axle gears, and noticed that these where not the axle tube outer dust seal, these where literally spindle seals.
So where can I find the tube dust seals?
By the way no special tools are needed, only need to be careful to not damage the new seals.
I also changed the inner seals, and same thing there, many say that a special tool is needed, but I only used iron bar and hammer and a screw driver.
Old Sep 3, 2013 | 05:10 AM
DetailerDave's Avatar
DetailerDave
The outer dust seal actually, according to Ford service manual, presses onto the axle shaft, and sits right at the end of the axle housing. Usually at disassembly, the dust seal is flapping around loose. The big seal you have shown goes into the steering knuckle, using the tool vortec 1 has shown, after the axle shaft is installed.
Old Sep 3, 2013 | 05:58 AM
Linne's Avatar
Linne
Yes I noticed that when I did my front end last weekend.
The tool is not needed, or if you never before has had anything to do with seals then it could be a good idea to use the special tool but it's really not needed.
Old Sep 3, 2013 | 06:35 AM
MisterCMK's Avatar
MisterCMK
There is a new design for the dust seal that presses into the axle housing rather than onto the axle shaft.
Old Sep 3, 2013 | 09:46 AM
Linne's Avatar
Linne
where can I buy this new model?
Old Sep 3, 2013 | 10:11 AM
MisterCMK's Avatar
MisterCMK
I got my seals from Ford.
Old Sep 7, 2013 | 06:32 AM
Linne's Avatar
Linne
That is the problem, I can't get them from Ford here in Finland as Ford in europe do not have anything to do with american Ford models, the only Ford truck/pickup you can buy as new here is the Ford Ranger. Anything bigger than that you need to import your self.
jawroper
Jun 2, 2015 08:35 PM
adammdennis11
Oct 29, 2013 11:26 AM
clux
Feb 17, 2013 10:23 AM
zakk
15
Mar 12, 2011 06:05 PM
roninator223
Nov 15, 2009 09:21 PM
