Cassette tape stuck in
Old Oct 26, 2013 | 01:33 PM
Icefan71's Avatar
Icefan71
My wife uses a cassette tape style ipod adapter in our Expe. It kept ejecting itself for some reason. So she tried a regular cassette tape. Now that is stuck in there. When you push the tape button, the display says "no tape". When you hit eject, it makes some noise like its gonna eject the tape but nothing happens. She said she tried getting a pair of pliers in there, but it didn't fit. I tried a little prying with a screwdriver with no luck. This is the original factory radio with cassette player in the head unit and CD changer in the center console. Any suggestions?
Old Oct 26, 2013 | 04:10 PM
alloro's Avatar
alloro
You're not going to pull the cassette out. When it goes in there is a metal stem that goes through the cassette. Your only option to remove it without damaging the radio is to remove the radio and pull the covers off it to get at the cassette.
Old Oct 26, 2013 | 09:59 PM
Icefan71's Avatar
Icefan71
Ughh. Thanks Alloro. I don't really wanna take the radio apart. I'll see if my wife can live without it.
Old Oct 27, 2013 | 02:08 PM
alloro's Avatar
alloro
Oh to be young and naive again...
Old Oct 27, 2013 | 02:42 PM
alwaysfords41's Avatar
alwaysfords41
Check to see if there is a pin hole near it, some cassettes have a release you can push with a pin.
Old Oct 27, 2013 | 06:38 PM
ajonesnv's Avatar
ajonesnv
What was stuck in a what? What is this cassette you speak of?
Old Oct 27, 2013 | 08:20 PM
Icefan71's Avatar
Icefan71
Long ago, just after dirt was invented there were these things called cassette tapes. Perhaps you can learn about them in a history book or at a museum.
The stuck tape mysteriously popped itself out when my wife started up the Expe today. I'm thinking of pouring cement in the cassette player and sealing it up forever .
Old Oct 28, 2013 | 09:41 AM
alloro's Avatar
alloro
The stuck tape mysteriously popped itself out when my wife started up the Expe today. I'm thinking of pouring cement in the cassette player and sealing it up forever.
Ah good, fortunately luck was on your side. Try a strip of clear tape over the opening instead of pouring cement into it. You'll thank me later.
Old May 29, 2022 | 05:52 PM
jeffrules98's Avatar
jeffrules98
1st Gear
Solved
Disconnect and reconnect the battery, it resets the radio and you can then hit eject
7475ih
Jun 27, 2025 06:34 AM
Aftrmidnite
Nov 21, 2017 07:16 AM
TXtinct
Aug 17, 2011 12:26 PM
67aj
Mar 3, 2009 10:06 PM
tcesni
Escape & Escape Hybrid
Nov 29, 2006 07:38 PM
