I believe it's 8" and the 20"s are 8.5" if my memory serves me correctly.
You can comfortably fit up to a 305mm width without having too much wear concern. 305 will be close to rubbing the upper control arm though. 295 seems to be the sweet spot.
Ah, never thought to check the sticker for wheel width... thanks guys! I'll check.
I'll likely add 2" of height, want to keep it mild, so I guess my main concern is fitting on the wheel (I know lots of flexibility depending on tire) and lock-to-lock rubbing issues.
I'm running 295/70-18 Nitto Terra Grapplers (34.4 x 11.4) on my stock chrome pkg wheels, 2" AutoSpring level kit- 3" rear blocks also for a +1.5" additional lift out back. Around 42 psi rear and 45 front and in 30K miles they are still in great shape and wearing decent but I try to rotate them every OC
