One thing about the car, there is an overabundance of torque on tap (300 ft/lbs) from the electric motor, but the programming holds back on the reins to about 115 ft/lbs at all speeds/RPMs. I believe there is an inclinometer in the car, because I see different behavior in the throttle when going up a steep grade. The car is actually quicker going up a steep grade... as quick as Stinky from 0 - 30 up that same grade. Once the turbo lights up, Stinky is an animal unleashed and finds the need for a tooth pick after his Prius patty.
i've heard that before...where FWD vehicles climb/tow better ,uphills then RWD?
This is different. That steep grade (on par with some Seattle city streets) is on my daily commute, and the Toyota Corolla (FWD with a bigger engine) was a dog up that hill... it barely made it to 30 MPH in about a block (floored and rowing hard). The electric motor really kicks in and I hit 30 MPH in about 1/3 the distance.
