Stock 6.0 changing boost ??
Old Oct 24, 2013 | 11:24 PM
jf490's Avatar
jf490
Is there a way to change the boost on a stock 6.0 with a snap on or other computer
Old Oct 24, 2013 | 11:31 PM
MisterCMK's Avatar
MisterCMK
What do you want to change?
These are the humble words of MisterCMK sent on the go...
Old Oct 24, 2013 | 11:56 PM
jf490's Avatar
jf490
Looking to raise it , maybe 35psi or so it's only making high 20's now
Old Oct 25, 2013 | 12:05 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You'll lift the heads at that PSI...
Josh
Old Oct 25, 2013 | 06:21 AM
npccpartsman's Avatar
npccpartsman
You'll need a flash programmer to do that. As Josh said, high 20's is plenty on a stock non-studded truck or you'll lift the heads.
Old Oct 25, 2013 | 07:43 AM
jf490's Avatar
jf490
Can I do studs with out pulling the head ? Do one bolt at a time my head gaskets are fine ! Truck has 115xxx not sure if they where ever done b4 I got the truck I had it since 65k
Old Oct 25, 2013 | 07:55 AM
npccpartsman
I know it's been done with success but most competent tech's and machinists don't recommend it. It's worth a shot and you really have nothing to lose but some time. If at some point you find yourself needing headgaskets then the studs are definitely reusable.
Old Oct 25, 2013 | 10:57 AM
jf490's Avatar
jf490
I think ill give it a try . Like u said worst case need to do gaskets. I've done it in cars b4 but I don't know enough about the 6.0's to know how it will react
Old Oct 25, 2013 | 03:05 PM
npccpartsman
I was trying to think who did it so you could read the posts.... I'm not sure if you start with the first bolt in the torque sequence or last. Either way it's gonna be fun getting the back one on each side done. RLMF.....
Old Oct 25, 2013 | 03:08 PM
Bullitt390's Avatar
Bullitt390
https://www.ford-trucks.com/forums/8...-hvac-box.html
Josh
Old Oct 25, 2013 | 03:10 PM
npccpartsman
Originally Posted by Bullitt390
That's it!! Thanks Josh
Old Oct 25, 2013 | 04:05 PM
jf490's Avatar
jf490
Thanks so much for all your help great info I'm going to give it a shot !! Now to find studs for the right price only ARP of course !! Maybe injectors at the same time ill be in there might as well do it
Old Oct 25, 2013 | 04:25 PM
Bullitt390's Avatar
Bullitt390
Look into polishing the spool valves versus replacing injectors just for the same of it.
In all honesty if I was in the mood to switch to head studs I would likely do the one for one method as well. It's done all the time in racing and heavy equipment so it isn't a new concept or anything.
Josh
ycis
Aug 27, 2013 07:39 PM
baddad457
15
Jan 13, 2012 01:22 AM
clean '97
Apr 6, 2011 06:39 AM
'02STROKER
Apr 25, 2007 03:23 PM
Banshee Ben
Nov 10, 2005 07:45 PM
