djm lowering kit
Old Oct 23, 2013 | 08:11 PM
smooth171's Avatar
smooth171
djm lowering kit
Hey I used a the djm 3/4 lowering kit on my 1978 ford f100, and I want to know is there a way I can get about another 1" or 2 more inches in the rear ????
Old Oct 23, 2013 | 08:31 PM
oddfordjunkie's Avatar
oddfordjunkie
How many leaves do you have in the packs? Still sprung over? Which hangers does your truck have, there was taller and shorter ones used factory.
Probably start by taking out the thick overload leafs on the bottom of the packs.
Old Oct 23, 2013 | 10:27 PM
Aztec209's Avatar
Aztec209
I agree with oddfordjunkie ^, I came across a similar situation but instead of me using DJM Lowering I-Beams (Which they are crazy expensive) I ordered custom spindles (4 inch drop) and I used some cheap aftermarket hangers for the rear (ha I'm so cheap ) I ended up removing the second to last overload leaf.
Old Oct 23, 2013 | 10:50 PM
HIO Silver's Avatar
HIO Silver
Where'd ya get custom spindles???
Old Oct 24, 2013 | 12:32 AM
blue04.5's Avatar
blue04.5
I've read you can swap the spindles side to side and gain some drop is this true or myth?
Old Oct 24, 2013 | 11:58 AM
hivoltj's Avatar
hivoltj
A word of caution : you do not want the truck sitting level at rest. If it does it will look like a squatting dog or pre-runner going down the road. The rear suspension compresses when loaded from the torque to move the truck.
If not hauling you want to be between 3/4" to 1" higher in the rear (I prefer 1")
If the truck is used to haul or tow at all, 2" at least higher in the rear and bags for heavy towing.
I just got some beams myself and am planning to do hangers and shackles in the rear, probably be about 2" higher than the front.
Old Oct 24, 2013 | 01:47 PM
Aztec209's Avatar
Aztec209
My local bodyshop, I don't know where exactly you can get them online, I've searched and was unsuccessful, although I did see a magazine at my local Walmart called "Classic Trucks" were they were available for $98 each (F100- F150 Only) about 2 months ago.
I've heard something similar but for early 70's fords, not sure if it will work for the 6th generation.
Old Oct 24, 2013 | 01:48 PM
jsutton's Avatar
jsutton
Sorry
I'd like to know about these too, because I've always heard lowering spindles weren't made for our trucks. I know you say custom, but I don't see how you could have custom spindles made for less than some off the shelf dream beams.
I'm sure I'm not the only one who would like to see some pics of the set up.
Old Oct 24, 2013 | 05:17 PM
Aztec209's Avatar
Aztec209
Originally Posted by jsutton
Sorry
Ha, you're not the first one, my neighbor was interested as well, right now I'm currently attending ELAC here in East LA, I'll be back home next month.
If I remember correctly from what they told me(at the bodyshop):
* You could also have your beams bent as a cheaper alternative, even cheaper:
* Cut the coils, and re-align the beams (when they re-align they drill out new holes on the beam supports), *problem*, it only lowers about 2-3 inches and on really hard bumps, the beams will hit.
Old Oct 24, 2013 | 05:47 PM
oddfordjunkie
I understand your thinking behind this but going to have to disagree. My 78CC sits level at rest, rides level on the freeway and starts to squat at 700 Lbs in the bed. I have the same leaf pack as a half ton with the 2-1/4" wide leaves.
I went up instead of down by doing a shackle flip in the rear and making coil spacers for the front that bolt on under the spring cup. I plan to take a couple leaves out and put my overload bags on so I can have a softer ride empty and still level it when I hook the trailer up.
79_effie
Ford Truck Parts for Sale
Oct 9, 2010 09:58 PM
johnmcarguy
Jun 22, 2006 01:53 PM
*Big_Swede*
Nov 12, 2003 01:28 PM
sb2371
Mar 29, 2001 07:43 AM
Gene
Sep 18, 1999 09:28 AM
