Sponsored by: Real Truck
Battery Drain
Old Oct 23, 2013 | 05:11 PM
Reagansd350's Avatar
Reagansd350
Battery Drain
Has anyone else had problems with their after market stereo or amp draining their batteries? I have a 2011 F350 and started having a dead battery all the sudden about a month ago. I brought it to ford, they did a diagnostic and found a small draw which we assumed was from the amp. After new batteries and a trip to Car Toys to get the amp swapped (what a pain in the *** ) it is still going dead on me. Any thoughts?
Old Oct 23, 2013 | 05:43 PM
redford's Avatar
redford
FTE Leadership Emeritus
Define "a small draw." Key off, how much current is flowing?
Old Oct 23, 2013 | 05:45 PM
RV_Tech's Avatar
RV_Tech
My first step would be verifying it was the amp, before swapping parts. How fast is the battery going dead? Has the battery been checked and tested good? There are multiple things that can cause this symptom.
Steve
Old Oct 23, 2013 | 07:15 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I find some of the videos on this page to be useful
BBB Industries - Technical Video Center
Check out the one that says "Troubleshooting parasitic battery drain"
Old Oct 24, 2013 | 04:32 PM
Reagansd350
What they found at the dealership was a 90 mili amp draw after doing a draw test. They replaced both batteries and about and week later it died. That was before swapping the amp. I came to the decision to swap out the amp after I disconnected the amp from the battery and the problem disappeared. When they pulled out the amp the claimed that there in fact was a draw and put in a new amp. (or so I hope, they did it for free).
Old Oct 24, 2013 | 05:13 PM
Torklift Sheryl's Avatar
Torklift Sheryl
SPONSOR
Battery Power
Something you might consider if you are looking for extra battery power is the HiddenPower. It is essentially a no-drill battery mount that attaches to your truck frame allowing you to keep a spare battery constantly charged. So if you are like me and you like to go to a meet or two and blast your stereo through the day without killing your battery, you might like this.
You can learn more here: HiddenPower - Under Vehicle Battery Mount
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Old Oct 24, 2013 | 06:42 PM
madsonp's Avatar
madsonp
Did you have your alternator tested, it could be going out and not fully charging you batteries.
Old May 17, 2015 | 10:44 AM
Forest Halleck's Avatar
Forest Halleck
Got same thing on 2003 550 Ben at it a while .Lots of info on 6.0 and Excursion forms on parasitic drain several threads .Eric the car guy on U Tube has a good video. Good Luck. Out.
Reagansd350
6.7L Power Stroke Diesel
Oct 23, 2013 06:07 PM
00Dave
Oct 5, 2011 07:40 PM
plowboy2
Jan 23, 2009 11:58 AM
yendor
Aerostar
19
Dec 6, 2004 10:58 AM
Drawsoncad420
May 22, 2002 11:13 AM
