Sponsored by: Auxito
heater defrosted controller help
Old Oct 23, 2013 | 04:42 PM
fordfan1997's Avatar
fordfan1997
Need a little help have a 97 f150 and lost the control of the selector switch. Can't switch between the panel defrost and blend functions my temp controlled still works fine just can't put air on full windshield defrost any ideas.
Old Oct 23, 2013 | 05:06 PM
Aftrmidnite's Avatar
Aftrmidnite
There is a check valve behind the battery that may have gone bad. If you do a hard acceleration does it attempt a switch over? If so replace the check valve assembly
Old Oct 23, 2013 | 05:41 PM
fordfan1997
No it never works at all would it be the switch
Old Oct 23, 2013 | 08:23 PM
Aftrmidnite
I would still check the check valve and the tubing associated with it, lot easier to get to that than go under the dash, the switch is a ported switch that moves the vacuum from one damper to another, usually what breaks is the **** or switch stem. Do you have a hand operated vacuum pump?
Old Oct 23, 2013 | 08:26 PM
fordfan1997
Yes I have a pump like to bleed breaks but need to figure out an adapter.
Old Oct 23, 2013 | 10:19 PM
steve(ill)'s Avatar
steve(ill)
there are 3-4 different vacuum cylinders on the system to open and send air to defrost, dash, floor, or a combination of the above. If you loose all vacuum the cylinders close and you get defrost only. I dont understand when you say you dont have full defrost ? Unless the doors broke off the cam, the system defaults to DEFROST.
Old Oct 24, 2013 | 10:11 AM
fordfan1997
Ok in truck now controller apart everything works act side. Turn the dial to panel&floor get panel for sure don't feel alot of floor. Move switch to floor and get defrost and for the floor/defrost no sound change then to all defrost again no noise change. So the floor solenoid must be bad correct
Old Oct 24, 2013 | 10:50 AM
BCHauler's Avatar
BCHauler
Pull the selector **** off and check that the post isn't stripped or the **** female side isn't cracked. both things happened on mine.
Replacing the control unit solved my problem. $10 at the pick'n'pull. Good luck.
Old Oct 24, 2013 | 12:15 PM
fordfan1997
Switch is fine pulled the controller that is by the gas pedal the yellow and blue lines go go it worked ok with hand pump took a little getting back on but works fine now maybe it just came unhooked or was little stuck and the hand pump loosened it up. But it works thanks everyone.
gstecki1
13
Aug 5, 2015 05:20 PM
Shawns Fords
13
Dec 14, 2011 04:23 PM
hdbiker04
Jan 6, 2011 09:51 PM
shane7209
1997 - 2003 F150
Jan 18, 2004 10:43 AM
Big Bad 1Ton
Aug 11, 2002 03:27 AM
