03/04
Old Dec 13, 2010 | 09:29 AM
SwanyRiver420's Avatar
SwanyRiver420
03/04
Would a March build on a 6.0 'o4 be considered a early or late build? Pretty sure I need to replace the ICP sensor on my truck but not sure if the part is the same.
Old Dec 13, 2010 | 09:37 AM
w_huisman's Avatar
w_huisman
Look under the hood of your truck.
If the ICP is under the turbo near the fire wall, as shown here, you have a early build.
If the ICP is in the right valve cover, as shown here, then you have a "late" build. (bottom of the picture, red/orange thing under the hot turbo discharge pipe)
Old Dec 13, 2010 | 09:40 AM
High Binder's Avatar
High Binder
Mine was built after yours and my ICP is in the rear under the turbo.
Old Dec 13, 2010 | 10:36 AM
SwanyRiver420
If it is a 3 connector wire harness then mine is an easy fix up on the manifold on the passenger side. Pretty sure this is it.
Old Dec 13, 2010 | 10:40 AM
npccpartsman's Avatar
npccpartsman
Check the VIN tag on the door. If it's built March 04 someone has replaced the motor if your ICP is under the turbo.
Old Dec 13, 2010 | 10:42 AM
npccpartsman
I hope you mean on the passenger side valve cover---yes that's it--04 engine.
Ford part# 4C3Z-9F838-AA
Navistar part# 1845428C92
These are the latest I have and should fit 04 from 9/22/03 up to 07 trucks
Old Dec 13, 2010 | 12:23 PM
High Binder
Whopps, for some reason I had it in my head his was built March '03. NC you're right. Mine was built about 6 months earlier than the OP's.
Old Dec 13, 2010 | 12:26 PM
SwanyRiver420
Got the parts and will attempt the fix tomorrow when I have a little more time. Yep, valve cover is right. I take it the new harness is a splice off of the old, am I correct? Also why do Ford dealers have varied pricing on these parts? I went a little farther and got the set-up for almost $50 less. Seems weird.
Old Dec 13, 2010 | 12:30 PM
npccpartsman
LMAO--don't even get me started on parts pricing. It's kind of a sore subject for me.
Just curious, but why are you replacing the ICP? They don't often go bad on the later model trucks, at least that I've heard. Any particular code?
Old Dec 13, 2010 | 01:42 PM
SwanyRiver420
2285 is what I have gotten. The light comes on, stays for a couple days and the goes away(emission light). Then will come back on again, really hard start this am like I've never had before.
Old Dec 13, 2010 | 02:08 PM
High Binder
Yep, I had that code too and the new sensor fixed it.
Old Dec 13, 2010 | 03:01 PM
KRDiesel's Avatar
KRDiesel
Has anyone ever relocated there ICP on a early 03. Having it under the turbo is a pain.
Old Dec 13, 2010 | 03:07 PM
npccpartsman
Never heard of it but don't think it would be that hard, actually. Maybe extend the harness, change the pump cover, valve cover, and oil rails?
Not really sure exactly what the 03 ICP screws into.
Old Dec 13, 2010 | 03:22 PM
KRDiesel's Avatar
KRDiesel
It just screws into the pump cover. I am thinking that you could run a hard line from the pump cover to a spot under the degass tank, and extend the harness.
Old Dec 13, 2010 | 04:07 PM
npccpartsman
It would have to be a damn good hard line. Remember it has to withstand 4000 psi. That would be readily doable though with a little research. The replacement plug-ins come with a fair length of wiring IIRC.
