180* Carb on a DP
I've thought about the idea before but I figure they designed it so they know what they're doing. The smaller passages are designed to increase velocity, especially as lower speeds when you need the torque. At those speeds you're not really going to need the large capacity anyway. Then, when it's opened up, the richer, fuller secondaries have the big space to go through. Makes sense to me.
But, as said, won't hurt to try!
I've always wondered what the difference, if any, in the volume between the primary side and secondary side. It's not something that can be found in the Offy specs. I think the only way to determine that would be by blocking the ports on the head side and filling the primary side and the secondary side with water and noting any difference in the amount of water used from side to side.
I believe the DP was made for near oem engine, slightly raising flow above stock for a 2 or 4v carb, but keeping the cfm down so the flow is not lazy.
**Oh yeah, I wanted to take this opportunity to say how happy I am that I'm "gaining momentum toward becoming a positive member of this forum." That just gives me a warm and fuzzy feeling all over.
I think it's the same thing as the smaller primaries. The increase in air speed helps the fuel atomize better when air speed could normally be sluggish, which gives a better pedal response at low RPMs.
But yeah, it was made for near stock engines.
Awww, I've always thought you've had a sunny disposition.
78bigunns
07-13-2012 01:28 AM
Andy_Bracy
19
12-16-2005 08:08 PM
