Accessing headlight power source
Old Oct 21, 2013 | 07:49 PM
kefrko's Avatar
kefrko
2000 f350 CC 7.3L I am looking for some advice on the best place to access the switched feed for the headlights. I installed some glow shift quad pillar gauges. They have a seperate wire that when powered dims the gauges by about 30-40% that they recommend hooking up to the headlights. I left it off for a couple of weeks to see how bright they are at night and if it would be necessary. Well I finally decided to look or a spot to hook it up. Tried to access the back of the headlight switch but had some trouble getting it out. I also looked at the wires going into the driver side headlight and considered tapping in there. Wanted to know if the little splice connectors are a decent way to tap into and wire that already run or if it's not advised.
Old Oct 21, 2013 | 08:42 PM
tappit01's Avatar
tappit01
this may be helpful in gaining access to the switch wires.
http://www.riffraffdiesel.com/mm5/RE..._Gauge_Pod.pdf
WA_PSD
Feb 2, 2012 10:09 PM
riggz
Jan 19, 2009 12:44 AM
apbtpetey
Electrical Systems/Wiring
Feb 6, 2008 11:31 AM
horses4fun2
Dec 31, 2004 08:06 AM
joners
May 5, 2004 05:20 PM
