3 prong headlights and dimmer switch question
Old May 3, 2004 | 09:09 PM
joners's Avatar
joners
Need help with my head lights, how do they work exactly? They are 3 prong, ground, hi and low beam. When they are on low beam, does 12 volts go into one prong, then on hi beam there is 12 volts going to the other prong. So there would be 24 volts total going through the light? also, the dimmer switch, does it act like a N/O N/C switch?
Old May 3, 2004 | 11:16 PM
KenB's Avatar
KenB
Not 24 volts, only 12 at a time being fed to one or the other terminal.
Switch does just that, switches feed (through wiring) from one terminal to the other.
Old May 4, 2004 | 06:11 AM
joners's Avatar
joners
Well here's my problem, I hooked up the headlights, driver side works fine, passenger side is very dim, with headlights on, you get 12 volts on driver side, 4 volts on passenger, take the headlights out, you get 12 volts on all contacts. If you have the driver side headlight out and the passenger side in, it doesnt even work at all! Whats going on??
Old May 4, 2004 | 06:56 AM
PJS55's Avatar
PJS55
I believe that you have corrosion or wire breakage somewhere between left and right headlight, likely at the left headlight connection. The left headlight installed improves the connection a little. With no current flowing, you might see 12 volts everywhere but as soon as the current flows, the resistance offered by the poor connection, limits current flow and hence the low voltage at the right headlight. Again, I would look at the wiring connections at the left headlight connection particularly the wire coming from this connection over to the right headlight.
just my thoughts.
Regards, John
Old May 4, 2004 | 08:26 AM
KenB's Avatar
KenB
Ditto on PJS55. Check for frayed wires, loose connections, etc. all the way back to the switch in the cab as well as dimmer switch. Any slip or terminal type connection would probably benefit from cleaning and re-assembly with dielectric grease.
Inner workings of the dimmer switch is also a possible culprit.
The headlights themselves, are the terminals tight on them? If you can detect any looseness, discard and replace.
Old May 4, 2004 | 08:34 AM
pootscratch's Avatar
pootscratch
In some cases, dim lights means poor grounding. Check any ground wires that you might have....maybe something is loose, or corroded and not making proper contact.
Old May 4, 2004 | 09:19 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I agree with Vern on the ground. Everytime I've had a headlight problem where one is dim, it has always been a ground problem...
Vern
Old May 4, 2004 | 09:21 AM
Jag Red 54's Avatar
Jag Red 54
Ditto on the above suggestions. Before you start taking things apart though, I would have somebody watch the brightness of the light while you wiggle the wire progressively back to the switch. It may flicker showing you where the bad spot is. Good luck, John
Old May 4, 2004 | 03:54 PM
joners's Avatar
joners
Well I got home from work and went straight to tinkering with it. I'd get 5 ohms or so then turn on the light, check resistance again and it'd shoot up to 5 MEGA ohms :|
So I put the ground to another screw on the headlight bucket and voila, it works.
The stupidest things agrevate me the most! :@
Old May 4, 2004 | 04:27 PM
GreatNorthWoods
Grounding problems can cause some weird symptoms. Try working with an all fiberglass car or one with a wood dash sometime....
Vern
Old May 4, 2004 | 04:58 PM
joners's Avatar
joners
Vern
LOL
The instructions on the Ron Francis kit says the exact same thing in bold
Old May 4, 2004 | 06:27 PM
Razortec's Avatar
Razortec
This is why I run a separate ground for:
Tail lights
Front park/turn lights
Headlights
Horn
Ignition
Dash equip.
This way I know that mostly my grounds are near perfect...
Old May 5, 2004 | 07:06 AM
GreatNorthWoods
Let's face it...YA JUST CAN'T HAVE TOO MUCH GROUND!!!
Vern
Old May 5, 2004 | 07:12 AM
Bob Ayers's Avatar
Bob Ayers
Don't check resistance with power on!!! You can ruin your meter....
Old May 5, 2004 | 05:20 PM
joners's Avatar
joners
I know.
must be 10 chars
saxmancon
May 2, 2022 04:48 AM
sooboy460
Jul 8, 2014 04:29 PM
Skalywag
Jul 3, 2014 08:50 PM
Hopsing69
Mar 11, 2014 10:45 PM
rottenstock
15
Sep 16, 2013 07:32 PM
