Bilsteins are awesome
Old Oct 23, 2013 | 08:24 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Thumbs up Bilsteins are awesome < that ain't no lie!
Do I mount the shocks with the boot pointing up or down?
With the internal design of the Bilstein monotube gas shocks, it does not matter whether the shocks are mounted with the shock rod side up or down. There are some minor advantages in longevity and overall suspension effectiveness with the shock rod pointed down, and there are many instances where Bilstein has changed the orientation to take advantage of these minor improvements where there are no clearance problems. If there is an option, we recommend mounting the shock with the shock rod and boot pointing down, but in the grand scheme of things, there is no noticeable difference.
i went and installed my fronts (i don't even recall which way now,id have to look lol) and then went to install the rear to match the way i did the fronts but couldn't.i had to mount them the other way cus they didn't fit when i tried the same way as i had just installed the fronts and i dunno if i could have swapped the fronts around or not.since i had checked first and saw the instructions posted above,i knew it didn't matter so i left 'em.
anyway,really nice shocks.they handle washboard dirt roads excellent.so not sure what the story there was.this is how i checked them out upon install.compared to my still good shocks,they made washboard dirt roads smoothed out.the difference was hard to believe.this is where these things shine and you can see what your $ got you.
Old Oct 24, 2013 | 08:19 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel
the fronts were easy to do rod-down, but I can see that maybe the backs have to be the other way since the mounting location loots like there might not be enough room for the boot to pass by the axle - and from driving behind newer trucks, it looks like its rod-up on the SDs since they shock mount hangs down below the axle and the shock tube fits quite snugly between the sheet metal flanges of the mount (the fixed dustcover on stock shocks is better than the shock tube itself).
anyway - nice to hear the good results with your shocks. i'm looking forward to some more testing of mine.
Old Nov 8, 2013 | 06:28 PM
OldWoodsDiesel
to revisit this thread - I liked my front Bilsteins so much, I went ahead and did the rear as well. and yes, due to the bushing setup on the rear shocks, they can only install rod-up. oh well.
now that I have 4 new shocks and have rebuilt my driver's seat, I swear this truck rides as good, if not better, than the day it rolled off the assembly line. I just took it for a 1 drive this morning with my son to pick up my venison sausage and kielbasa and I was amazed at the ride. its definitely a stiff suspension, but you barely feel the bumps and they don't resonate at all.
thanks again for the advice FTE!
Orezona
50
Dec 14, 2012 06:13 AM
mwsmith100
May 28, 2011 10:34 PM
orthogod1
Nov 14, 2010 09:38 PM
ChambersF150
1997 - 2003 F150
Nov 30, 2009 07:27 PM
jimb206
Sep 15, 2005 07:19 PM
