Can I just replace lifters?
Old Oct 20, 2013 | 10:57 AM
Ripcity's Avatar
Ripcity
I am putting on new head gaskets and re sealing the top side of on my 360. The upper portion of my engine has A LOT of sludge. My engine ran very smooth no lifter noises. However it has 130K on the motor. Can I replace the lifters with new ones without changing the cam?
Old Oct 20, 2013 | 11:16 AM
nine inch rear's Avatar
nine inch rear
Yes, you can do new lifters and same cam, but not new cam and old lifters. Look closely at the cam once the lifters are out. That might tell you if you want to use the same cam.
Old Oct 20, 2013 | 12:31 PM
mikeo0o0o0's Avatar
mikeo0o0o0
If you start to do the change but for some reason decide not to, be absolutely sure you put the old lifters back in the same bore they came out of.
Also, be sure to use a break in lube on the new lifters and use an oil that has adequate amount of ZDDP in it, or use an additive that does.
351Cleveland C4
13
Sep 1, 2014 12:03 AM
73F100*8Mile
Jan 25, 2006 09:40 PM
kentuckyranger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 24, 2005 11:35 AM
h-m
Sep 20, 2004 01:25 PM
fuzz
Feb 27, 2001 08:46 AM
