cam/lifter question
Old Jan 25, 2006 | 07:42 PM
73F100*8Mile's Avatar
73F100*8Mile
cam/lifter question
ok quicky question, just out of curiosity can you use a set of "used" lifter on a new cam if they only have 5,000 miles on them? will they re-mate to the new cam? i know it's not worth the risk and better to just get new lifters but i was just wondering.
Old Jan 25, 2006 | 07:52 PM
rusty70f100's Avatar
rusty70f100
Absolutely not. That would guarantee failure.
Old Jan 25, 2006 | 08:18 PM
pkulaga's Avatar
pkulaga
its possible to use new lifters on an old cam, but NEVER OLD LIFTERS ON A NEW CAM, or any cam for that matter. I had to learn this the hard way cause I was cheap and figured that "one old lifter won't be a problem, I'll just lube the crap out of it". As soon as I started to run the cam break in, it started bogging down in about 10min. Freaked me out so I quickly shut it down and tried to crank her over with a wrench, it was rather hard and I knew that I had either spun a main bearing or worse. Turns out that my old lifter immediately starting wiping the lobe, then the lobe ate through to the plunger in the lifter. Needless to say, 4 lifters were no longer lifting and 4 lobes were no longer...... lobeing.
Old Jan 25, 2006 | 08:50 PM
73F100*8Mile
dang, that'll stick in my head for future no-no's
Old Jan 25, 2006 | 09:40 PM
ceetwarrior's Avatar
ceetwarrior
That's amazing! Why is that? If the lifters are "like new" why would it destroy that new cam even with good grease?
