Steering Column Fix HELP!
Old Oct 19, 2013 | 12:28 PM
bradford237's Avatar
bradford237
So my steering column seems to be slowly shifting a bit to the left. The steering wheel doesn't face flat toward the driver. Any ideas on what's causing this? Seems like there is also alot of wiggle in the steering wheel.
1978 F150 4X4
Thanks!
Brad
Old Oct 19, 2013 | 01:31 PM
montana_highboy's Avatar
montana_highboy
Sounds like a worn upper column bearing...
Column Bearing, Upper
Old Oct 19, 2013 | 01:42 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Wiggle? Check the column bearings like montana said. If the whole column has shifted, first, check the bolts under the dash, make sure they're tight. Next check the body mounts, make sure they're okay and haven't collapsed.
Old Oct 19, 2013 | 03:46 PM
AZ F250's Avatar
AZ F250
Got the same problem on mine, gonna check out the bearing too!
Old Oct 19, 2013 | 06:00 PM
dlburch's Avatar
dlburch
is it a tilt wheel? the top of the tube can weaken and break which lets the bolt come loose.
ChristopherBarnette
Jul 16, 2021 01:06 AM
frdnut
May 19, 2006 12:25 PM
76 F150 Ranger XLT
May 10, 2006 04:10 PM
rews2
1978 - 1996 Big Bronco
Apr 12, 2006 10:23 AM
79_ford_400_guy
May 20, 2003 02:52 PM
