4 Way flasher
Boy do I feel sheepish! AS several of you said, I checked the fuse. It was good... Tonight I went out to check the wires to the flasher and the flasher switch. I looked at the fuse again and went to remove it to get a better look and lo and behold the 4-ways started working when I jiggled it! I removed it and it looked dirty, slightly corroded, a bit rusty. I cleaned it up with emery cloth and put it back in and they work...
Also, I put the heavy duty 4 way flasher on the turn signal wire because it clicks louder. This is good cause my right side signal does not cancel itself. Incidentally, I temporally had the TS flasher on the 4 way wire and the 4 ways worked. I did buy a HD Flasher however, since I figured the TS flasher would burn out if I kept it in...
Thanks for your help!
