f100 4x4 manual steering box
Does anyone in oregon have a manual steering box for an F100 that i could get for a reasonable price? I know that I should swap in a power steering box, or get a rebuilt one, but being 16, i don't have the money. Even a junkyard in the area. Any input would be appreciated.
Many thanks,
Brennan Johnson
Many thanks,
Brennan Johnson
Any used gearbox you find won't be any better than the one you have now, could be worse.
You can have yours rebuilt by redheadsteeringgears.com .. located in Seattle WA
Look at the parts catalog pic: The parts that are replaced in rebuilt boxes are: 3552/3553 bearing cups, (2) 3571 bearings & especially (2) 3576 sector shaft bushings.
All are obsolete, but all are available NOS as are the 3581 gasket & 3591 seal. Buy the parts (I'll list the part numbers/sources) and fix it yourself.
You might be surprised. The one in there now will not turn to the left very well. Once you move past the center, it gets vibrations up the steering shaft, and feels like it is slipping. Could this be a bearing, or is it possibly something more serious, like a worm gear with broken or warped threads?
Thanks for the info,
Brennan Johnson
Brennan Johnson
Ahhh. My money is on the steering linkage being your problem not the gear box then. Have a buddy move the steering wheel back and forth and watch the linkage to rub something or get jambed up. Especially in the area you have the problem.
1965GTFB
04-08-2018 07:51 AM
TheRedlines
01-17-2017 12:09 AM
Mister_King
15
06-21-2016 02:54 AM
brenjimin
13
07-26-2012 10:59 PM
palsymonkey
07-13-2006 09:28 AM
