code 1249
Old Oct 16, 2013 | 10:13 AM
ben duncan's Avatar
ben duncan
code 1249
code 1249 new billet wheel on turbo, pulling 1500 lb rv on 7 degree hard wot this code and ses light
Old Oct 16, 2013 | 03:07 PM
ben duncan's Avatar
ben duncan
code 1249
2002 7.3 psd ,motorcraft ais intake, 4 inch exhaust ,gearhead tunes, riffraff billet wheel and boots on all turbo pipes , was pulling 1500 lb rv up back mountain in tune 3 wot running about 52 to 55 mph egts about 1100 light comes on all the time pulling on down side light goes off ,when i get to campground check codes i get 1211 1249 340 and603 help
Old Oct 16, 2013 | 04:04 PM
senix's Avatar
senix
Moved to the 7.3 forum for better assistance
Old Oct 17, 2013 | 10:14 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
This should help you out.
KH5 DIAGNOSTIC TROUBLE CODE P1249 — CHECK KOEO FOR P1690
DTC P1249 indicates that the PCM detected the turbo was overboosting.
Possible causes:
short to ground
plugged WGC hose or port
WGC solenoid
WGC actuator
WGC valve
damaged PCM
Perform KOEO On-Demand Self Test.
Is DTC P1690 present?
Yes.............No
GO to KH1 . GO to KH6 .
KH6 CHECK WGC HOSES
Disconnect the RED hose from the WGC actuator.
Install Gauge Bar 014-00760 vacuum pump or equivalent to the hose.
Does the hose hold vacuum?
Yes.............No
GO to KH7 . GO to KH8 .
KH7 CHECK INTAKE PORT
Disconnect the RED hose from the charge air cooler housing.
Does hose still hold vacuum?
Yes.............No
REPLACE WGC hose. RESTORE vehicle. CLEAR DTCs and RETEST. CLEAN out plugged charge air cooler housing hose port. RESTORE vehicle. CLEAR DTCs and RETEST.
KH8 CHECK INTERCOOLER PORT
Install vacuum gauge to the port.
Does the port hold vacuum?
Yes............................................... ...............................................No
CLEAN out the plugged port. RESTORE vehicle. CLEAR DTCs and RETEST. GO to KH9 .
KH9 CHECK ACTUATOR
Install vacuum gauge on the WGC actuator.
Does actuator hold vacuum?
Yes.............No
CHECK WGC linkage for sticking. REPLACE if necessary. RESTORE vehicle. CLEAR DTCs and RETEST. REPLACE WGC actuator. RESTORE vehicle. CLEAR DTCs and RETEST.
Old Oct 17, 2013 | 10:22 AM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Do you have a boost gauge? if you have a gauge what was your boost? you may be setting an over boost.
CWUF250
Oct 7, 2009 11:03 AM
F150'89
General Automotive Discussion
Oct 31, 2004 06:19 PM
easpilman
Jul 3, 2003 12:08 PM
