Sponsored by: Auxito
'97 sway bar question
Old Oct 16, 2013 | 03:03 PM
460 FORD MAN's Avatar
460 FORD MAN
I just acquired a '97 f150 4.6 2wd. The previous owner said it was involved in a wreck. A car ran a red light and it a car that hit the truck. The frame is slightly bent on the drivers side in front of the control arm.
Any way, the truck has a lot of sway going around corners/curves. It is very loose. Is it supposed to be like that?
Click on the pic to see a video...
Old Oct 16, 2013 | 04:02 PM
ewalt98's Avatar
ewalt98
You're joking, right? That sway bar is doing absolutely nothing as is.
Looks like you are missing a bush on the top, as well as the end link not being connected to the lower arm. Everything should be tight, from the sway bar bushing to the end links.
I would take the front end apart and rebuild it completely after verifying the frame has been straightened properly.
Old Oct 16, 2013 | 07:22 PM
67' Dually's Avatar
67' Dually
x2. It looks like the bottom bushing on the end link got knocked down through the mounting point on the control arm. I have the same truck, just replaced mine.
Old Oct 16, 2013 | 11:47 PM
460 FORD MAN
Thanks guys! I found what I need.
agsmv1
Mar 12, 2015 11:18 PM
tsbrewers
Feb 23, 2012 07:13 AM
smokinbucs
1997 - 2003 F150
Feb 3, 2007 03:02 AM
02f350Longy
Mar 27, 2006 08:15 PM
MENESLIS
Feb 18, 2004 11:54 AM
