Head Studs
Old Oct 17, 2013 | 06:15 PM
CPB1's Avatar
CPB1
I believe I read somewhere that all OEM head bolts are TTY (Torque To Yield). This includes 7.3l as well as Cummins and Duramax. The TTY bolts stretch just a little, which is why they can't be re-used.
The studs don't stretch.
Old Oct 17, 2013 | 06:26 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Studs stretch also.
Old Oct 17, 2013 | 06:38 PM
Shake-N-Bake
Originally Posted by Smokiesman
Could some tell this old man what the diff in holding power of studs over head bolts and why ??
Smokie
A bolt gets rotated in its shaft in order to thread into place. This creates both twisting and axial forces on the bolt. When placed under load (in this case when cylinder pressures are most extreme, the heads want to separate from the block) the bolt has to deal with two different forces at the same time. As a result it's strength capacity is reduced a bit.
A stud can be tightened into place with little to none twisting force. This means the fastener is only subjected to axial force, which results in a higher rating capacity.
The Oldsmobile Quad 4 engine had common studs that secured both the cylinder heads and the main bearing caps. During assembly they were torqued to stretch vs torque to yield. Those engines were virtually bullet-proof when pumping out power at extreme levels.
Torque to stretch is a far more accurate method. Back in my racing days, I used to purchase Mopar ARP connecting rod bolts for my cast iron Pontiac engines. I torqued them to stretch and routinely had engines making power will into the 6,000 rpm range (which isn't very common for the Pontiac design...)
Old Oct 18, 2013 | 11:08 AM
Smokiesman's Avatar
Smokiesman
Excellent explanation ! I think I have it figured out now!
Smokie
1973dieselhighboy
Competition
Feb 6, 2015 12:17 PM
FordManiac1242
16
Sep 26, 2012 12:34 PM
1989f250IDI
Aug 6, 2012 03:23 PM
kenworthfan
Apr 28, 2010 12:02 AM
ford4.9
6.4L Power Stroke Diesel
44
Dec 4, 2005 12:00 AM
