Head studs for boost
Old Aug 6, 2012 | 11:45 AM
1989f250IDI's Avatar
1989f250IDI
WHo can find head studs for my 1989 f250? The cheapest i can find is $500
Old Aug 6, 2012 | 01:28 PM
RA31925's Avatar
RA31925
Do head studs need to be professionally installed?
Old Aug 6, 2012 | 02:37 PM
ihateminimumwage's Avatar
ihateminimumwage
Head studs are not cheap for the 7.3, that's just how it is. The bolts in the 7.3 are larger than the ones used in the 6.9, so the 6.9 was more prone to head gasket failure and the studs were more necessary.
And no, they do not need to be professionally installed, but it depends on your own abilities. They're much easier to do with the engine out of the truck, but I did mine with it still in. Only takes patience and some basic tools (including a good torque wrench.)
Old Aug 6, 2012 | 03:23 PM
kobaltblue's Avatar
kobaltblue
They are a good safety thing but if your not going to boost above 15psi you should be good...Many have boosted above with out problems....But I wouldnt do it unless you put new head gaskets in.
mudguts
Jan 20, 2011 11:10 PM
George D.
13
Mar 28, 2009 12:23 PM
crack
Oct 26, 2007 03:54 PM
santacruzf250
Jul 9, 2007 10:27 PM
jboard
Feb 23, 2006 06:23 PM
