Need some help Please!!!
Old Oct 14, 2013 | 10:12 PM
JDDriver87's Avatar
JDDriver87
Well its been a while since I've been on here but I need some help. I am a mechanic, and I've worked on a ton of 6.0, and I own 2. But I ran across a problem thats kinda got me confused, and I'm trying to save some time because the owner doesn't have much money to spend. The truck started with the warm no start. Then it started to skip some what. Well at first I was thinking a leaking oring on stc or pump or dummy plug, but then it was starting with no problem, but still skipping. Well I checked the icp pressure, and tested the ficm and did a contribution test. Well the right bank showed all cylinders having a problem. After this the guy needed to leave, and had to take the truck. He called me, and told me it quit on him. So I went to the truck, and it fired up no problem. Well he has been driving it two days now with no problem, but it smokes terribly while accelerating. (Black smoke) but runs out fine. Any ideals or suggestions?
Old Oct 15, 2013 | 09:52 PM
Tom's Avatar
Tom
Hi JDDriver87, welcome to FTE!
From your post it seems that you are talking about a 6.0L engine, and in this case you posted in the wrong forum. I'm moving this one down to the 6.0L Powerstroke forum, you should get some more replies down there.
Old Oct 15, 2013 | 10:02 PM
Lilpooh's Avatar
Lilpooh
What year motor (not truck)? 03-early 04, late 04, or 05-07.
Old Oct 15, 2013 | 10:33 PM
04badford's Avatar
04badford
Any DTCs, may need to hook a scanner on it and monitor
1. FICM
2. EGR
3. ICP
4. ICPV
5. IPR
how does the Turbo sound also get VGT
Old Oct 16, 2013 | 11:58 AM
JDDriver87's Avatar
JDDriver87
Thanks Tom. The truck is a early 04. I checked all the voltage and pressures, and everything is in operating range.
Old Oct 16, 2013 | 01:43 PM
POORBOY1964's Avatar
POORBOY1964
Wire chaffing issue?? if only one bank is showing problems that would help narrow it down.
Old Oct 16, 2013 | 02:26 PM
bismic's Avatar
bismic
I would recommend doing an injector bubble test.
Old Oct 16, 2013 | 03:57 PM
Clay H's Avatar
Clay H
Sounds like an injector stuck open. Park it and crawl under it and look for fuel at the exhaust manifold where it meets the block. If you see any fuel seeping out, that injector is dumping fuel.
jblksmith1
Nov 9, 2014 03:12 AM
acf6
Jan 6, 2013 03:45 PM
dannyboy1130
Nov 25, 2011 02:42 PM
bblancha
Sep 2, 2009 04:22 PM
