Help Needed 6.0 Powerstroke 2004
Old Nov 8, 2014 | 04:56 PM
jblksmith1's Avatar
jblksmith1
After a major battle all day between my brother and the HPOP we found out that I ordered the wrong one. Apparently my truck is a 4/04 model. The HPOP I ordered came with a new STC and IPR in the box. I now need to reorder the correct HPOP. Is the IPR and STC different from what I have, what I ordered and what I need?
Thank you for your continued support on this forum.
In case I forgot to mention, I hate this truck.
Joann
Old Nov 8, 2014 | 05:15 PM
04badford's Avatar
04badford
so you have the early built 04 with the ICP under the turbo? post up the Numbers you have and lets see ?
Old Nov 8, 2014 | 05:20 PM
jblksmith1's Avatar
jblksmith1
Still trying to figure out the Scan Gauge II. Bullet proofed the FICM and changed the ICP. Looking to replace HPOP and IPR and STC. Truck has not cold started in years and ran rough at every traffic light idle. Recently had to be towed home twice for refusing to hot start after stopping at a store. Just started replacing all the known to fail parts. My question was is the STC on this production year truck a problem and is the IPR different from the late 04 models?
Old Nov 8, 2014 | 08:49 PM
daddykitty's Avatar
daddykitty
no stc fitting on an 04..ipr goes from 03-04 and 04-07.
Old Nov 8, 2014 | 09:03 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Lots of good info in this thread. Including part numbers for pump and ICP and some pictures. https://www.ford-trucks.com/forums/1...firmation.html
Yes, there are 3 part number pumps. First two look the same. '05 and newer have a different design and is the only pump to use the dreaded STC fitting.
Old Nov 9, 2014 | 03:12 AM
jblksmith1's Avatar
jblksmith1
Thank you!
rsplash40
Dec 26, 2011 11:16 PM
boeingoing
Mar 18, 2010 10:14 PM
Northriver
Feb 6, 2006 10:07 AM
PeteJa
May 9, 2004 09:37 PM
keck.sc
Apr 16, 2004 01:34 AM
