98 F-150 SuperCab Running Board Repair ???
I have a 1998 F-150 Lariat SuperCab with fiber-glass running boards. The running boards have a 5" wide rubber tread that runs approximate 2/3 of their length and wraps the outer edge. The front 8" of the passenger side tread has detached. What is the appropriate product to glue/seal this rubber tread back in place? Thanks in advance for your help and suggestions.
Some type of contact cement that you paint on both parts, let dry for 10 mintues, then press together, would work.. Problem is everything has to be clean and rough surface so it will stick. You might have to peel up a few more inches or remove the rubber to clean it good (alll dirt and crud out) , scuff with sandpaper, and install.
100550dvr
25
05-08-2019 08:13 AM
billb7984
08-04-2003 04:47 PM
