2nd Gear Pops Out
Old Oct 14, 2013 | 02:27 PM
Paynster's Avatar
Paynster
2nd Gear Pops Out
I have a 1946 1/2 ton with rebuilt engine and tranny. The rebuild was in the late 90,a. If I do not hold it in second gear, it will pop out sometimes and make a noise that scares the bejesus out on you. I obviously will need to pull the transmission. What causes this and should I consider rebuilding the transmission again?
Old Oct 15, 2013 | 10:03 AM
f5fordgirl's Avatar
f5fordgirl
Three or four speed, if 3, it could be a bad synco, or the syno teeth on the gear are worn, or too much back and forth movement in the main shaft. If 4 spd, may be 2nd gear is badly worn, or a shifter fork is bent.
Old Oct 15, 2013 | 07:53 PM
Paynster's Avatar
Paynster
It is a 3 speed.
Old Oct 15, 2013 | 10:54 PM
GB SISSON's Avatar
GB SISSON
I think you have a case of sloppy seconds. I had it in my jeep.
Old Oct 21, 2013 | 11:32 PM
geomechs's Avatar
geomechs
Shifter detents, input shaft bearing, output shaft bearing could be worth checking. I'd also look closely at the needle bearing between the input shaft and main shaft; they are often overlooked.
Old Dec 29, 2013 | 10:27 AM
Mike Moss's Avatar
Mike Moss
2nd gear pops out
Check your main shaft end play. There is a spec as I recall. If you replace the bearings make sure the retainer rings are correct width and fit the grooves correctly, should be tight. I learned the hard way. The ones that come with the bearings may not be correct, and allow the main shaft assembly to move back and forth, which can cause it to pop out of gear!!!!
Big John Hance
Oct 5, 2022 09:40 AM
Captain Call
Aug 26, 2018 10:20 AM
87white250
Jan 20, 2008 05:36 PM
#8trx450r
Jul 24, 2007 08:19 PM
Oval_obsessed
May 3, 2005 11:17 AM
