300 6 Emissions
Old Oct 13, 2013 | 11:07 PM
cstephens's Avatar
cstephens
Talking 300 6 Emissions
I'm in the process of buying a 1983 F-100 with 300 6. I asked the current owner about a hose he had blocked off with a piece of a broom handle. He said it was where the smog device had been. Can anyone give me information on the emissions device on the I6?
Old Oct 13, 2013 | 11:17 PM
85e150's Avatar
85e150
It is possible he blocked a hose that came off the "smog pump", or Thermactor air pump. This is a drawing of that system, yours would be similar if not identical:
http://www.fordification.com/tech/im...tor667E100.jpg
It is also possible you have/had an EGR set up, which is a pipe from the exhaust to the intake via an EGR valve.
You will have evaporative controls as well, which capture fumes from the fuel tanks and hold them for intake via hoses and charcoal filled canisters.
Old Oct 13, 2013 | 11:48 PM
dosequis's Avatar
dosequis
my thread started only moments before yours...sounds like we're in a similar situation, but you may be in a better one. I'll be curious to see which way you go...no smog or restore to original. good luck.
Old Oct 14, 2013 | 04:31 PM
cstephens's Avatar
cstephens
I don't know. That drawing is....confusing, to say the least (at least it is for a 16 year old in a high school automotive VoTech class). I don't follow that a bit.
Old Oct 14, 2013 | 07:04 PM
dosequis's Avatar
dosequis
the diagram might be helpful if it has a key...also not sure if it is for an 83...that common rail thing doesn't look like anything I've seen on any 83.
Old Oct 14, 2013 | 07:40 PM
cstephens's Avatar
cstephens
I'm screwed...............
Old Oct 14, 2013 | 10:00 PM
85e150's Avatar
85e150
The hose that is plugged--where does it go?
That common rail is the manifold for air injection into the exhaust manifold. Not all thermactor systems worked that way.
That drawing is a '66-67 E100, but the basics of thermactor systems are the same. Air pump, hoses, and so mechanism to inject the air into the exhaust.
Old Oct 15, 2013 | 09:36 AM
1986F150six's Avatar
1986F150six
cstephens,
It is good seeing that a 16 year old is in a high school automotive VoTech and is interested in a 1983 Ford F100 with our beloved 300 six cylinder.
Do not worry, members of this forum are knowledgable and willing to assist. If you can provide photos of the hose and all around it, others will be able to help you. Keep in mind, your truck is now 31 model years old and most likely has passed through a few previous owners, each with his own idea of what makes an engine run better. It can be difficult to return an emission system to its original state. Where you live [Hot Springs, AK], does your truck have to be inspected and pass emissions?
Old Oct 15, 2013 | 01:03 PM
cstephens's Avatar
cstephens
Originally Posted by 1986F150six
cstephens,
It's Arkansas and no I don't think so. I don't think I care about having it back, so long as it won't affect the truck's performance or gas mileage. it won't will it?
Old Oct 15, 2013 | 01:19 PM
85e150's Avatar
85e150
For that model year, which I assume predates the feedback carb, the only emissions item that might cause running issues would be the EGR. And I doubt it would in your case.
Half removed emissions items can lead to vacuum leaks.
Also, anything to do with the evap system should be left in place and made functional. OR, removed completely, and the fuel venting must be moved to the rear of the vehicle. The worst case is a butchered evap system with gas fumes venting into the engine compartment. Good formula for a fire.
Old Oct 16, 2013 | 06:04 PM
cstephens's Avatar
cstephens
cstephens,
I'll try to get some pics, but I don't have the truck. I'm paying on it, and the guy is hanging on to it until I get it paid off. He's letting me do work to it until then, tho.
Old Nov 25, 2013 | 09:40 PM
codejunkie's Avatar
codejunkie
Other members here are professionals and will have technical info for you. I can tell you that my '89 4.9 (F-150 body) has had the "smog pump" (pumps air into the exhaust manifold) removed. The pump system was "T.U." when I bought the truck, along with a lot of other stuff. Machine Shop could not find a replacement pump/related parts to make it "stock" so they just deleted the pump and hoses/pipes hooked to it. They inserted proper size bolts into the holes in the exhaust manifold where the fresh air used to be pumped in. (or rather, where it would have been if the system had been functional).
The loss of the "Smog Pump" apparently made no difference in the running of the engine, even though it was designed to adjust the exhaust before the exhaust hit the sensor located before the expensive "cat". Which is supposed (?) to adjust the fuel/air mixture to avoid clogging up the "cat".
"However", there are several other devices that should be working properly to have your engine run well. Just off the top I remember the Intake Air Sensor (screwed into the intake manifold), the Engine Coolant Temperature Sensor (screwed into the coolant system), the EGR components to include the part that feeds the voltage to the valve if it's that type, Throttle Position Sensor, and probably a couple others that I can't remember right now.
The EGR valve does several things that are supposed to make the engine run better. All the other devices feed info to the computer which then sends back commands to adjust the timing and fuel to achieve the best performance.
"If" your state requires an emissions test, the absence of the "smog pump" could cause your engine to be refused emissions certification. If your gas gage says "Use Unleaded Fuel Only", and the vehicle has no "cat", then it will also be refused emissions certification and you cannot register the vehicle to get your license plates. I learned that the hard way on a fancy Jeep I bought one time and then moved to a city that required emissions testing before license registration.
What I'm trying to say is; if the car has a "computer" and if the engine is seriously messed up regarding the original sensors and other emissions/computer related hang-ons, then you may have a fair amount of work replacing/fixing those items before it will be worth your hard-earned money.
Good luck on your purchase, and congratulations for choosing an excellent engine for your first. I looked for two years before finding mine, and it required a *lot* of repairs. Which were worth the end results.
enrgizerbunny
Nov 9, 2016 09:16 PM
coreye1976
Mar 31, 2009 11:06 AM
mike demos
Jun 1, 2005 02:12 PM
Percy
Oct 23, 2004 02:24 PM
steakman_usaf
Jun 20, 2000 11:32 AM
