Breaker points continuity
Old Oct 14, 2013 | 03:29 PM
truckpastor's Avatar
truckpastor
Helpful advice, thank you
Old Oct 14, 2013 | 03:50 PM
old_dan's Avatar
old_dan
Originally Posted by truckpastor
That's what I thought. The base of the point grounds to the distributor housing if I'm looking at it right with a braided wire. And the negative leads, condenser get juice from coil. So if I am getting continuity with points open and closed...I've got a short/grounding issue. Maybe my wire braid is rubbing against something it shouldn't? I know about electronic points but I'm stubborn about getting it running before upgrading too much
The condensor (really a capacitor) will look like a circuit to your digital multi-meter. You do need to check that the points are opening and closing the coil circuit, but you'll probably have to unhook the condensor to make it look like a normal switch to the meter. For the test, the points should basically be the only thing in the circuit with you meter.
Dan
Old Oct 14, 2013 | 04:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by old_dan
The condensor (really a capacitor) will look like a circuit to your digital multi-meter. ...
Dan
But it shouldn't have continuity? If it does, it's clearly bad
Old Oct 14, 2013 | 05:16 PM
old_dan's Avatar
old_dan
Ross,
A discharged capacitor that is attached to ground will look like a path to ground to a digital ohm-meter....for a couple of seconds, then it will charge up and appear to be an open circuit. Unless you have a buzz-box that is a circuit tester that uses an AC current....that will work normally. Also, I haven't been having much luck with the condensers/capacitors that I've been buying lately....it is very possible to have a shorted condenser causing problems.
The best practice is to isolate that points circuit from all of the external features for diagnosis. That way if the screws are shorting out the points it'd show up right away.
Dan
Old Oct 18, 2013 | 07:14 PM
truckpastor
an update...i went basic and did continuity test after disconnecting and reconnecting each component
points break there continuity as they should with negative leads connected to coil, condenser connected, but the moment i connect the positive wires from ignition switch to coil, i get this problem where i have continuity all over the points and distributor body even with points open.
working it out
Old Oct 18, 2013 | 07:48 PM
JWC 3's Avatar
JWC 3
I like to use a teat light , not a meter . Like you static time one .
Old Oct 18, 2013 | 08:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Are you using an ohmmeter to test for continuity? Or a test probe with a light?
Where are you measuring continuity from, when you are checking the points? Ground?
ALBUQ F-1's Avatar
ALBUQ F-1
I GREATLY prefer teat lights, too!
Old Oct 18, 2013 | 08:49 PM
JWC 3's Avatar
JWC 3
Yup Should have been test , heck
Old Oct 18, 2013 | 09:22 PM
ALBUQ F-1's Avatar
ALBUQ F-1
LOL, Just pulling your leg!
Old Oct 18, 2013 | 09:31 PM
JWC 3's Avatar
JWC 3
I still prefer using a TEST light for these old systems . I sold My 73 VW with 408K on it . I did a lot of point testing and setting over the years ! Now my tractors and my 53 are all I own with points . I still break out the test lamp .
Old Oct 18, 2013 | 09:33 PM
JWC 3's Avatar
JWC 3
By the way I gave $300 for the Vdub , years later , Sold for $1250 !
Old Oct 24, 2013 | 08:09 PM
  #28
truckpastor
Problem solved! Turns out I have a short in the ignition switch wires going to coil. Replaced with a new wire and it fired right up
Old Oct 24, 2013 | 08:14 PM
  #29
JWC 3's Avatar
JWC 3
Glad you got it fixed ! THANKS for posting your fix ! I hate dead threads .
itsfordornothing
Jun 11, 2018 03:48 PM
jb50F1
26
Jul 5, 2010 07:37 PM
tn.jed
May 6, 2010 06:29 PM
MO-55F350
Dec 9, 2009 06:26 PM
nick65f100
Oct 18, 2005 06:22 AM
