I do have a superchips tuner, and I restored my prior PCM to stock, so I know I can reuse it. can my existing PCM be re-programmed, or flashed or whatever to repair it?
What problems are you having with the PCM that you feel it needs replacing?
My shop is telling me that they are getting several codes which indicate PCM issiues. not sure which ones.I have 2 PCM's each throwing different codes, so, I found a PCM for 300, and it is on it's way. I will post the results here in a few days after it arrives.
Thanks
Carl
Thanks
Carl
