94 460 MAF Conversion
What is the complete list of components and work I'll need to convert from speed density to MAF in a 94 F250 with a 460, 5 speed manual.
ECU from 96 or 97, right tranny
Engine harness
What MAF sensors can I use? Does it have to be a particular size?
Any other sensors I'll need?
I'll also be replacing the distributor, coil, plugs, wires, wiring harness, hell maybe even key cylinder. I'm having wildly sporadic ignition problems and I'm done with it. Yard sale on sketchy ignition parts.
Any help is greatly appreciated. I'd like to have all my parts gathered in a week or two. Thanks for reading!
Engine harness
You can use a mustang ECM and mass air sensor. Best ECM is a A3M as it has a higher calibration limit.
