Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all:
- Why is my Truck Whining?
Guide to diagnose trouble and recommended solutions
Browse all:
Rear end whining at 35+ mph, need lots of help
Ugh. I am moving 1000+ miles on friday(towing a small boat) and my rear end is whining pretty loudly now at 35+mph.
I'm really in a bind here, I have never done any work on a rear end before and wouldn't even know where to start to try to diagnose it or repair anything. I guess I'm going to see if I can find a shop that will guarantee they can have it done in a few days at most.
If anyone has any advice at all, I'm all ears. What does whining usually indicate and what is the worst case scenario here.
This sucks.
1996 5.8L Bronco
This sucks.
1996 5.8L Bronco
I would start by changing the gear lube. It could just be low, but if it's making noise it's already doing damage. Getting fresh gear lube in there could extend the life for a while though.
I've never heard a U-Joint "whine". They will "squeak" and "clunk", but a "whine" says rear end to me.
3/8" ratchet and pull the fill plug...On level ground, the oil inside should be level with the bottom of the hole...
9/10 whining is bearings. do the above suggested things, check fluid and u-joints, but most likely its the pinion bearing goin up. check pinion bearing by removing d-shaft from rear yoke and try to move pinion back and forth by hand. a leaky pinion seal can also be indicative of a worn bearing
This is one of the things I had to get used to when reading forums - sometimes there are lots of widely-disparate opinions.
In this case, one guy is saying 99% are caused by low gear oil, the other guy says 90% are bad bearings....
Take it for what it's worth, I guess....
Not trying to be critical or judgmental or anything, just stating an observation that took me a while to get used to....
low oil by itself wont cause it to whine, you could drain all the fluid out and drive it around and it wont whine, but it wont be long before the bearings are destroyed. most people dont realize theyre low on fluid until their rears start making noise and they go back there to investigate. . .
adding more fluid, better fluid, or thicker fluid can quiet worn bearings back down to an acceptable level if the bearings arent too far gone. he, in essence, was making the exact same point.
low gear oil = bad bearings.
I hear what he is saying though. Someone asks for help and they get 10 different answers, and everyone is always "99% sure" that their answer is the right one. Happens in just about every forum.
Yep, low oil doesn't make any noise, its the bearings and/or gears destroying themselves due to lack of lubrication that makes the noise. Getting the proper amount of oil back in there can help save it for a while, but if it's making noise the damage has already been done.
Yeah, that's actually why I suggested changing the oil instead of just filling it up. If it's making noise, it's likely that there are metal shavings in the oil. It would be best to get all of that out of there so it doesn't cause any more damage, or at least keeps it to a minimum.
My rear gradually began whining over the years. Dad drove it for the first time in 4 years and commented on how loud the rear end was. I hadn't noticed because of a) gradually got louder, and b) too loud of music.
Anyway, pinion bearings were on their way out (play in the pinion flange) so I changed out all the bearings and crush sleeve in the rear end. The pinion bearing were the only ones that showed serious wear, but I had all the new ones there so I did all of them.
Now its super quiet.
I wasn't low on oil either. I think I caused crush sleeve failure by letting the tire spin, grab, spin, grab, spin, grab. Which hammers the crush sleeve. Eventually it crushed too much so the bearings had no pre-load, and they ate themselves.
Bingo...99% of "Whines"...Are simply low gear oil......The teeth meshing in and out are the culprit....Which causes heat...which in turn causes a failure....
Lakajin
