cluch problems
Old Oct 10, 2013 | 07:25 PM
old broke prospector's Avatar
Originally Posted by Wolfracing
How does one get the pilot bearing out? The old grease trick?
The use of grease and the clutch allignment tool will pop the busing out, you can fill the hole first with pretty much anything from nuts to a rag to reduce how much grease it will take.
Old Oct 10, 2013 | 07:35 PM
Wolfracing's Avatar
Wolfracing
Originally Posted by old broke prospector
How long to drop and replace a tranny? I am 61, fat, out of shape, ate up with arthritits, can't see and very slow. I pulled my 66 4 speed working a few hours per day, late in the pm when it cooled down........ 5 hours. Put it back in the same..... 5 hrs over a few day period..... by myself with air tools, a floor jack and a hydaulic jack for the engine.... the engine is going to drop down when you remove the tranny support so when going back in, you need to jack up the engine to be level with the tranny. Other than that, it is a simple labourous greasy, nasty but satisfying stressful job.
Will the engine move on a 63? All three support points are on the engine, and nothing on the trans......which I had not seen before. So I figured the engine would stay put.
If you were a neighbor I would certainly help you change a trans. I still have a bit of body to work with. Brains I'm not so sure.
Old Oct 10, 2013 | 07:56 PM
madman1966's Avatar
madman1966
it look ok but is it posibel if wasent ajusted back in to have pused past a presher plat finger because of to much constint presher
Old Oct 11, 2013 | 12:47 AM
daveengelson's Avatar
daveengelson
Well, can't wait for input should you need to lift the tranny, before doing so, got the impression the fork was loose (comment #7) in the housing and wonder if the retracter spring came out of the retainer; if so, suggest check and verify the clutch arm retracter spring is still attached to the fork ;items listed in Bill's comments "Clutch fork retracting spring (7523)"; it is possible to re-attach by moving the boot back and install the fork onto the throw-out bearing and push the fork as close to the shaft as possible, then move the fork back and try to maneuver the retracting spring on the retainer.?
Old Oct 11, 2013 | 08:37 AM
rogue40's Avatar
rogue40
I had a clutch fork bend one time. Cause the same problem as what the op is describing.
Old Oct 11, 2013 | 06:30 PM
madman1966's Avatar
madman1966
thank you every one for the help and advice i will definently let eveyone know what it terns out to be that is if i ever get a moment to actwaly fix it that is
Mitch1407
15
Sep 6, 2012 09:21 PM
lemcham
Sep 18, 2007 08:31 AM
robert steele
Feb 1, 2007 09:10 PM
choppers
1983 - 2012 Ranger & B-Series
Aug 29, 2002 11:16 AM
Wyoming Thumper
Dec 4, 1999 12:07 PM
