Random stuff
Old Feb 14, 2014 | 01:18 PM
  #136
husker's Avatar
husker
Smart phone and Navbar...... Does anyone else use a android or iphone to check in here on a regular basis. Mine phone just automatically switched to the Navbar when I log in and it is crappy. I don't like it at all.
Old Feb 16, 2014 | 07:54 AM
  #137
Flip4ford's Avatar
Flip4ford
sorry I tried once didn't go well so I use computer
Old Feb 16, 2014 | 08:12 AM
  #138
itsabullitt's Avatar
itsabullitt
On my windows phone now and it seems ok for replies to threads. Having to go searching
through the forums could be difficult.
Old Feb 16, 2014 | 09:10 AM
  #139
Garden Spyder's Avatar
Garden Spyder
I do it when I have FTE withdrawls, and need an FTE fix. its cumbersome but not too bad.
Old Feb 16, 2014 | 09:18 AM
  #140
husker's Avatar
husker
The previous form was a lot easier to use. This one is more jumbled and may have more options, but is a bit of a pain.
Old Feb 18, 2014 | 05:25 PM
  #141
ProjectDually's Avatar
ProjectDually
Android, and I'll view the forums, but posting is weird. Sometimes it just doesn't reply, or type right for some reason. So I'll just view the forums best I can when I am working, or when I know I'll not be at a computer for a couple months.
Old Feb 25, 2014 | 06:39 AM
  #142
Flip4ford's Avatar
Flip4ford
Good Morning--- Soooooo If you had a full width dana 44 (for free) what Gears/axles and lockers would you want to put in it?
Old Feb 25, 2014 | 06:44 AM
  #143
Garden Spyder
That depends on what its going into and what I would be using it for.
Old Feb 25, 2014 | 07:04 AM
  #144
74 bronco's Avatar
74 bronco
Driver side drop or passenger? high or low pinion? Standard or reverse rotation? 1/2 or 3/4 ton? oem axles or chromoly axles? leaf or coil spring or coil over or nitergen shock? Regular tie rod or ram asst steering? Front or Rear axle? 4 or 3 link?
Old Feb 25, 2014 | 07:36 AM
  #145
husker's Avatar
husker
Did you forget anything Clint? Good questions.
Old Feb 25, 2014 | 10:22 AM
  #146
Flip4ford's Avatar
Flip4ford
Driver side drop-- high pinion- Reverse rotation- oem axles coil springs or Regular tie rod -- Front axle-- 2 link track bar-- Weld on C mounts not solid. I do not know if it is 1/2 or heavy half or 3/4 ton. :-) I don't know if it has disk or drum but I am betting drum.
Old Feb 25, 2014 | 11:34 AM
  #147
HappyJack's Avatar
HappyJack
Well gears pends on what size tire and what trans/t-case you are gonna use. Lockers pends on what 4x4 system and what ya use it for. Axles pends one them first things an how hard ya play.
Old Feb 26, 2014 | 05:33 AM
  #148
74 bronco's Avatar
74 bronco
What rear axle you using and what gear ratio is it? How much money do you to build it?
If money is there I would do chromly axles,selctable locker if driven on street, gears wold depend on what gears are in rearend and if need to change for bigger tires.
Old Mar 3, 2014 | 06:34 AM
  #149
Flip4ford's Avatar
Flip4ford
Anyone need Novalog 70/30 quick pens-- Doc's office sent in the wrong script- insurance company won't take them back or refund- so I am out $350-- I would like to help someone out, instead of tossing them.
Old Mar 3, 2014 | 02:50 PM
  #150
HappyJack's Avatar
HappyJack
I have a co worker who is interested. Let me know.
