Sponsored by: Real Truck
6.0l starting problems
Old Oct 7, 2013 | 08:46 PM
Gettyd's Avatar
Gettyd
I have a 2006 f-250 powerstroke with 97000 on it egr delete exhaust and a h and s xrt pro on it. The pickup will always start when the engine and oil is cool, but once i run it for a while it and the oil gets warm it wont start back up again. I then have to leave it sit for a while and it will start. The engine just cranks but does not fire. I have replaced the dummy plugs on both sides and all the injector o rings on the passenger side. Some mechanic friends of min have had same problemed 6.0 liters and replaced these and it has fixed the problems i do not thjnks it my high pressure pump. Any suggestions?
Old Oct 7, 2013 | 09:34 PM
acf6's Avatar
acf6
most likely the STC fitting on the hpop. its like a $35 part, but a good couple hours of labor
Old Oct 7, 2013 | 10:07 PM
Jeff Watts's Avatar
Jeff Watts
Could also be the standpipes. Youtube 6.0 air-test.
Eth12
Sep 2, 2021 09:20 PM
boatmanspooner
May 22, 2016 09:46 PM
DaveO1990
General Diesel Discussion
Apr 8, 2013 07:29 AM
syoder333
Oct 13, 2009 09:55 PM
f250grs
Oct 24, 2006 10:49 AM
