Surging or lurching randomly
Old Oct 7, 2013 | 08:34 PM
HokieHiVPI's Avatar
HokieHiVPI
Hi there. I recently came back from towing my 7k trailer a few hundred miles and I've had a weird problem ever since.
My truck is non studded, EGR delete with SRL tuning. I went from the 8k tow back to SRL. When I did that, I noticed that my truck is acting like I'm stomping on the gas for a fraction of a second. It leaps forward for just a second. Sometimes it'll do it two or three times in a row, others just once and done. It doesn't seem to matter the speed, it's done it in park (where it almost choked itself out), 25,35,45 mph. It has NOT done it any higher than that.
I check the FICM voltage first. It's between 11.5-13V. It's reading between 47-48.5V on the other readout.
The EBP is in range as well with idle, etc.
The ICP has been kind of all over the place, but always over 580. When's it's surging, I haven't noticed a big drop off on the scangauge for the ICP reading.
It's about due for an oil/fuel filter change, but wanted to toss it out to see if there were any suggestions?
Old Oct 7, 2013 | 09:04 PM
Cubawashere's Avatar
Cubawashere
besides your filter changes... While engine running, wiggle ICP harness, since you said ICP readings were a little jumpy, it could be the harness itself. They're notorious for going bad.
Old Oct 7, 2013 | 09:05 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Just a shot in the dark but you could try wiggling the wires around above the throttle pedal assembly. Also monitor vRef when it's acting up. Could easily be related to the tunes or a fuel issue etc. But I'm thinking it might be wiring issue. Entirely based on readings from my magic 8 ball lol. Good luck, the intermittent stuff can be a PITA.
Old Oct 7, 2013 | 09:07 PM
Cubawashere
^^+1 Good call there too @Rusty
Old Oct 7, 2013 | 09:11 PM
HokieHiVPI's Avatar
HokieHiVPI
Thanks for both the suggestions. I just thought it was a bit weird that it did it after changing from the 8k back to the SRL. I'll pay attention tomorrow when I drive it, but I didn't notice it doing it after it warmed up... isn't that typically FICM related?
Also, sidenote: is it ok to switch from tune to tune without going back to stock first? I actually tried to go back to stock just to see if it was tune related and it failed twice.
Old Oct 7, 2013 | 11:15 PM
04badford's Avatar
04badford
Hoki back a few months ago didn't you replace the ICP pig tail? if not theres a grey clip at the connection that will be shorting out ,pull that clip off and look inbetween the three wires for bare, white or even burnt. the Surge and stall was my issue, replaced the pig tail now I have a happy truck, BTW the readings will be wack ICP,ICPV
Old Oct 8, 2013 | 06:20 AM
HokieHiVPI's Avatar
HokieHiVPI
Nope, I replaced the MAP and EBP sensors a while back, but this is the first go 'round with the ICP. I'll check it though, thanks!
Old Oct 8, 2013 | 07:21 AM
HokieHiVPI's Avatar
HokieHiVPI
Update: I did absolutely nothing to the truck overnight and drove it to work this morning with no surging whatsoever.
I'll see on the way home if it does it, and I'll still look at the ICP pigtail when I get there. Weird.
Old Oct 8, 2013 | 07:28 AM
mustang_309's Avatar
mustang_309
Doesn't the 03' 04' trucks have a VGT relearn function? I wonder if that would cause it?
Old Oct 8, 2013 | 05:38 PM
04badford's Avatar
04badford
I'm not sure Brett I bet M-Chan or Mark would know wheres Benny when you need him
Old Oct 8, 2013 | 05:41 PM
HokieHiVPI's Avatar
HokieHiVPI
I drove the truck to and from work today and it ran like a raped ape. Absolutely no surging whatsoever. I need to fill up with gas tonight or tomorrow morning and I'll see if it does it on a short, in town trip.
Old Oct 8, 2013 | 05:56 PM
04badford's Avatar
04badford
Yea Intermittent will Pizzz you off for sure, mine would do it seems like rough roads and hot temps never did it in the winter, but bad enough the truck will start to stall out, the grey clip fell out in my hand when I was done with the pig tail replacement that's when I seen the result and where it was, there are other spots for wire chaff and in the tech folders are a list of them, good luck bud.
Old Oct 8, 2013 | 06:14 PM
05F250DSL's Avatar
05F250DSL
DON'T FILL IT WITH GAS. All tho that might permenantly solve your issue.
Old Oct 8, 2013 | 08:37 PM
99ExpyProblems's Avatar
99ExpyProblems
lol ha ha ha
Old Oct 8, 2013 | 08:44 PM
78fordman's Avatar
78fordman
If the ICP looks good, something else to check would be the oil temp sensor. I had a 7.3 give me a fit like this one time. The connection was bad the the oil temp sensor and it would surge randomly going down the road. The oil temp would be right and then drop to -40 every now and again. When the temp dropped the engine would surge. Just trying to think outside of the box.
