Stinky - the continuing saga
Old Oct 6, 2013 | 06:54 AM
Tugly's Avatar
Tugly
I have a slow buildup of oil in my coolant (I'll get pictures soon), I suspect I'm getting small air bubbles in my oil, I have one injector that's the runt of the litter, and my fuel strainer was a temporary measure last winter.
None of these are show-stopping, they are just things that make Stinky less than 100%. October will be my final push to get this done, so I can just enjoy the end result of all the trials, tribulation, and Tourette's syndrome I've endured to get there.
  • I have a 9th injector set to my specs, just sitting on the work bench.
  • I'm ordering the Racor fuel strainer
  • Clay has my order for an oil cooler
  • The only thing I haven't replaced is the LPOP, so a Melling is coming in from Clay as well.
  • I'm going back to green coolant with the additive until I'm sure I'm done with all the contamination. I'll revisit the ELC in a couple of years... maybe. bfife has an interesting alternative I need to look into.
The wrenching will take place after my home improvements are done, but the bevy of Buck$Zooka blasts has begun.
Old Oct 6, 2013 | 07:13 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
By now you should have some velcro valve cover gaskets Tugly. Now I have another thread to follow.... sigh.
Old Oct 6, 2013 | 09:37 AM
BWST's Avatar
BWST
Got Data?
Rich, you decided to just get a new oil cooler? Would it be worth pulling the old apart to check the work, or just better at this age to replace?
I agree with you on the green coolant. I'm going to stick with that period - along with a coolant filter now in place.
Old Oct 6, 2013 | 09:46 AM
bfife's Avatar
bfife
still plays with trucks
Rich, I think if you do decide to go with the Evans Waterless you will be very pleased. I've been running it in my rigs since 2001. Never issue. there are a whole lot of positives, some of which are no cavitation, no electrolysis, no corrosion and no blown hoses.
here is a link for you.
Coolants » Engine Cooling Systems
http://www.evanscooling.com/
Barney
Old Oct 6, 2013 | 09:51 AM
Tugly's Avatar
Tugly
That's the bugger... I finally get those sticks to stick, now I'm going to yank one out.
I had a conversation with my expert and sometimes these things just leak after they've been messed with. Clay has them on the shelf for some reason, I can only guess I'm not alone with this leak thing. After all I've been through (and you have with coolant/cups), how much would you have paid to do it once and be done? In this case, the oil cooler is $225, but I am unsure if that includes the O-rings. I'm still trying to figure how to contain the mess. I can use my floor mats... they work for milkshake.
98wgefugfu3ebg
Apr 6, 2016 08:56 PM
Excurvelle
Feb 16, 2015 08:18 PM
Tugly
106
Dec 4, 2012 07:14 AM
SARDiverDan
Feb 26, 2012 10:34 AM
Jacobm
Apr 28, 2009 05:50 AM
