Headers Question
Old Oct 5, 2013 | 11:12 PM
Fordguy2002's Avatar
Fordguy2002
Headers Question
Hey guys I have a 76 f150 with a 390. I just got a great deal on a set of flowtech headers. I have a few questions. How hard will the install be I read that you had to jack up the engine on some threads others I read all you had to do was drop the starter and clutch linkage. Secondly I was wondering if I would have to have them welded under neath since the piping looks to be smaller where the manifold connects to the piping. I'd appreciate any advice,
Old Oct 5, 2013 | 11:41 PM
montana_highboy's Avatar
montana_highboy
Try consulting these guys....
Turn & Burn : Discovery Channel
Old Oct 6, 2013 | 02:23 AM
rockittsled's Avatar
rockittsled
which episode?
Old Oct 6, 2013 | 06:48 AM
montana_highboy
Episode 1 thru 13
They're always chopping up chit.
Old Oct 6, 2013 | 09:10 AM
Fordguy2002
I am actually trying to fix up my truck not chop it to **** but thanks
Old Oct 6, 2013 | 09:27 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Here is an example of what you need to connect, usually welded to existing exhaust pipe after cutting pipe to length, but have seen them connecting with" wrap around" clamps if you have a straight connection. These are ball and socket, others are fixed. Hedman 21115 Hedman Header Reducers
Old Oct 6, 2013 | 11:25 AM
HIO Silver's Avatar
HIO Silver
FYI...If searching/Googling, it's called an exhaust band clamp.. two versions - stepped for slip joints and straight for butted:
Old Oct 6, 2013 | 08:06 PM
Fordguy2002
Thanks guys that helps me a bunch. Do I need to drop the starter and clutch link to get my heAders in. I've read people saying they had to loosen the motor mounts and jack up the engine
Old Oct 6, 2013 | 11:15 PM
V10man's Avatar
V10man
This should tell you all ya need to know:
http://www.holley.com/data/Products/...3901FLTrev.pdf
Old Oct 9, 2013 | 06:35 PM
NW 150's Avatar
NW 150
I have a 75 f100 4x4 with the 390. I also installed flowtech headers on it a few years back. All that you need to do is remove the clutch linkage and starter. No jacking up the engine is necessary. I had to put a ding in one of tubes on the passenger side that rested on the starter.
FSCboss
15
May 8, 2018 03:02 PM
abyars111
Dec 28, 2013 09:40 PM
jenksf100
Apr 30, 2013 03:53 PM
Paul Therriault
27
May 23, 2006 09:57 PM
Goodold71
Exhaust Systems
Mar 7, 2003 03:23 AM
