Cracked flexplate?
Old Oct 19, 2013 | 09:47 AM
xtremexj's Avatar
xtremexj
Originally Posted by mustang_309
Have you tried running a 40 weight oil like 5W-40? To see if it calms the noise down?
I had been running 15W40 with AR9100 before this change and it was about the same. I figured that with the lighter synthetic blend oil it would be better with the cool weather starting. I normally do run 5W40 from Nov-April just due to the freaking cold temps we see up here.
Old Oct 19, 2013 | 10:24 AM
xtremexj's Avatar
xtremexj
Originally Posted by m-chan68
Worn cylinder #8 cam lobe(s).
Just out of curiousity, what is book time to r&r a cam in a 6.0L?
Old Oct 19, 2013 | 11:09 AM
cheezit's Avatar
cheezit
30-35 hours + parts would be my guess
Old Oct 19, 2013 | 02:33 PM
xtremexj's Avatar
xtremexj
Fuel pressure at idle is 75psi. I haven't driven it yet but I have been trying not to beat on it too hard considering the noise. I'll take it for a short rip in a while and see how the pressure holds.
Old Oct 19, 2013 | 03:15 PM
mustang_309's Avatar
mustang_309
If your fuel pressure is good at WOT I would have to wonder about the quality of the rebuilt injectors you're getting. I would also bubble test the fuel system to see if you have any other bad injectors or copper washers that aren't sealing. Remove the upper ( secondary ) fuel filter and with the cap off and filter out crank the engine over as shown in this video and watch for bubbles in the fuel filter housing,
Old Oct 19, 2013 | 08:33 PM
BLADE35's Avatar
BLADE35
I too wonder about Injectors
Shure was A lot of Smoke
Any sign of oil in the downpipe??
Old Oct 22, 2013 | 08:01 PM
xtremexj's Avatar
xtremexj
The diesel shop that sold me the injectors said it's nearly impossible that 3 different injectors would fail in the same hole that quickly so I don't know. I haven't pulled the downpipe but it's definitely raw diesel and not oil. Even once the truck is warm and stops smoking you can still smell diesel quite heavily.
I am starting to think valvetrain more and more. I couldn't get it into the shop today like I was supposed to because my guy has a HUGE back log of trucks to work on so I have to wait a week. I think I am going to pull the valve cover off again and try and measure the cam lift. Anybody have the lift spec for an early '03 cam - cam and valve lift? Might save my guy some diagnostic time if I can check that out.
Old Oct 22, 2013 | 09:43 PM
Yahiko's Avatar
Yahiko
You should be able to compare the cylinders on the same bank and get an
idea if one of the lobes have gone flat or had a lifter go.
Sean
Eli.Jp
Jan 17, 2017 08:18 AM
Nothin but a Ford
Mar 10, 2014 12:45 PM
srauner
Jan 27, 2014 02:29 PM
sandmn1010
Jul 12, 2011 01:05 AM
rampage_989
Dec 17, 2000 07:48 PM
