7.3 specialists...
Old Oct 4, 2013 | 01:19 AM
Xcursion88's Avatar
Xcursion88
7.3 specialists...
What are some symptoms of an ICP sensor acting improper.
Thanks
Old Oct 4, 2013 | 02:22 AM
Stewart_H's Avatar
Stewart_H
Moved to the 7.3L forum where the experts can get you the answers you're looking for.
Stewart
Old Oct 4, 2013 | 05:36 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Surging, erratic idle for one that's how I've found a bad ICP sensor.
Old Oct 4, 2013 | 05:57 AM
Tugly's Avatar
Tugly
That depends on which direction it fails:
If it reads artificially high, the PCM will try to lower your ICP. With low ICP and the PCM thinking it's normal, you have anemic performance - very anemic. In my case, I could drive highway speeds just fine, but acceleration and hill-climbing was pathetic. It will also run unusually quiet.
If it reads artificially low, the PCM will jack up your ICP. This adds more fuel than the PCM expects, so the engine will be jerky, smoky, loud, and the EGTs will be scary.
Old Oct 4, 2013 | 06:20 AM
kawcrasher's Avatar
kawcrasher
Oil in the plug for it is a sign to replace. Most leak before they fail.
Try unplugging it. If the truck runs better or there is oil in the plug it needs replaced.
Old Oct 4, 2013 | 07:25 AM
mueckster's Avatar
mueckster
This is the direction that my ICP sensor took recently. I experienced extended cranking while trying to start hot. I also noticed the ICP pressure (via my Aeroforce Scangauge) was dropping lower than normal when decelerating and at idle. Sure 'nuff, the connection was oily. Needless to say, a new ICP sensor is on it's way from Bob @ dieselorings.com. Thanks, Bob.
Old Oct 4, 2013 | 07:44 AM
Tugly's Avatar
Tugly
Caveat - the ICP will automatically climb at idle when you unplug it. I've heard pulling the plug on the sensor improves town driving if the ICP is bad.
Old Oct 4, 2013 | 11:54 AM
lhud's Avatar
lhud
Tugly,
That was my experience when starting on a round-robin trip from E. TN to TX and back. I had an oily coating on top of the sensor and remember reading that if disconnected it ran it would be fine as long as I was not towing. I disconnected the sensor and continued my trip and replaced it upon my return. All was well.
Old Oct 4, 2013 | 10:18 PM
Tugly's Avatar
Tugly
When mine went belly-up, I cleaned the connector with contact cleaner and put in some dielectric grease (to repel oil). All my power came back and I got home fine.
Old Oct 4, 2013 | 10:22 PM
mueckster's Avatar
mueckster
I thought about doing the same thing, but I have a spare vehicle to drive. I'm giving Red a rest 'til the new sensor shows up on Monday.
Old Oct 5, 2013 | 08:00 AM
Tact's Avatar
Tact
I just replaced mine yesterday.
https://www.ford-trucks.com/forums/1...ine-light.html
My truck continually got worse regarding symptoms. Eventually, it would die while stopped in traffic or going slow making a turn. Very dangerous!
Old Oct 5, 2013 | 08:11 PM
Xcursion88's Avatar
Xcursion88
Please take a look at this video. This has been a problem for a while. It only does it in the certain throttle position/rpm window. It never does it from a cold start. Only once it is warmed up. It does not always do this but more times than not it will.
if I push the go pedal it stops bouncing/surging/whatever...if I let off the fuel pedal and reduce rpm the surging bouncing etc goes away. It also at times acts like only some of the 8 cylinders are firing. (it gets quiet) Again though if I let off or push more pedal it goes away and runs normal and strong. Idle is good...with a very faint hiccup once in a while.
Hopefully you can hear my video enough to make some light of it...
thanks
Old Oct 5, 2013 | 08:43 PM
BigAlsPSD's Avatar
BigAlsPSD
Your video is set to private...
Old Oct 5, 2013 | 08:50 PM
Xcursion88's Avatar
Xcursion88
I think I fixed it. Let me know if you still can't see it.
Old Oct 5, 2013 | 09:16 PM
BigAlsPSD's Avatar
BigAlsPSD
Works now, very interesting that you aren't getting an SES light...does your light come on at KOEO test?
Have you tried this with the ICP unplugged to see if it will do it under the same conditions? Also made sure the Tin Nut is on the IPR?
Do you have a way to monitor live data? Curious about the Pedal position sensor as well.
