Check engine light, code P21B0 what is it?
Old Jan 21, 2019 | 02:26 PM
  #31
tavo_4x4's Avatar
tavo_4x4
P21B0 CEL
Just got mine checked out at Auto Zone and P21B0 popped up on the diagnostic computer. They couldn't tell me what it meant or was. Can anyone give me some advice. It's a 2014 F 250 FX4 6.7 with about 42,000 miles. Any help would be greatly appreciated.
Old Jan 21, 2019 | 03:29 PM
  #32
brmccolley's Avatar
brmccolley
DEF sensor/heater. Ford covered r/r cost.
Old Jan 21, 2019 | 07:48 PM
  #33
dirthawg's Avatar
dirthawg
Did you not read all the posts above you in this thread? Post #16 says it all.
https://www.ford-trucks.com/forums/1...l#post15402162
Link to the part in question.
https://parts.autonationfordwhitebea...-l?parent=1173
Old Feb 8, 2021 | 09:59 AM
  #34
Gaulois's Avatar
Gaulois
7th Gear
Hello, I had error code P21B0 on my 2016 Ford F250. I saw all the threads on it above. However, I keep seeing something about deleting codes? I'm interested in removing the whole Def thing, but don't know where to start.
Old Feb 8, 2021 | 10:04 AM
  #35
Gaulois's Avatar
Gaulois
7th Gear
How do you do deletes?
Old Feb 18, 2021 | 11:44 AM
  #36
Effies 56's Avatar
Effies 56
The DEF delete and codes are two different but connected animals. I took my truck to a shop to have the delete work done and a old man (stock) tune added. This was about $2K or less. But this was after much dealer work to try to get the truck to run well and not want to regen all the time. The codes dont show up now. and in my case the truck runs MUCH better. I am not recommending this delete as a cure all but in my case it came down to the only option, if I was going to keep the truck.
Regards,
Chris
Old Feb 18, 2021 | 12:57 PM
  #37
Gaulois's Avatar
Gaulois
7th Gear
Thank you for the reply. I decided to just have the problem fixed, after reviewing all the answers instead of removing the whole def system.
air1jpg
2004 - 2008 F150
Feb 19, 2014 09:22 PM
aphotic26
6.4L Power Stroke Diesel
18
Aug 30, 2013 05:15 PM
Fomhoire
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
39
Jul 13, 2011 02:17 AM
plankofwood64
1997 - 2003 F150
Oct 8, 2007 02:52 PM
Mulletwagon
Oct 6, 2001 08:23 PM
