Hi Guys, newbey with a radiator fittment question
Old 10-02-2013, 12:34 PM
Horizonmech's Avatar
Horizonmech
Horizonmech is offline
Greetings from Oregon, I just dragged home a pretty badd a## 1960 F100 4X4, 292 ci.
After some inspections this thing (running gear) looks pretty well put together, the body has some cancer but that's a problem for another day.
The problem at hand, it's been sitting in my neighbors yard for several years and someone has acquired/stolen the radiator.
After doing some Google searches all I'm coming up with so far is some E bay aluminum units and LMC (@$469, ouch). The parts listing seem really vague about interchangeability. Can anyone tell me if the core supports changed in 60 and made it a "stand alone" unit, i seriously doubt it but have nothing to compare to and there seems to be little if any eng compartment pic to be found. I have no problem with a new radiator off the bay if I can have some confidence it will bolt up. Thanks in advance and if this project advances I look fwd to making friends and being "in the club".......Cheers
Old 10-02-2013, 12:55 PM
Horizonmech
Old 10-02-2013, 12:59 PM
Horizonmech
That's a pic I found of a 57 with a Y motor, looks like just what I need, anyone know if it will bolt to my core support ??
Starting to think the 60 4x4 may be a bit of an oddity .......
Old 10-02-2013, 01:30 PM
Maltman's Avatar
Maltman
Maltman is offline
welcome and cant wait to see pictures of your truck!
you will be recommended to get a shop manual-at least once, I agree they are valuable...
I am not sure on fitment...all I can tell you is they the radiator on my 60 with a 223 has the lower outlet on passenger side. Someone will be along to help you, lots of great guys here. wish I could help more sirrrrrrrrr
Old 10-02-2013, 03:00 PM
oldebrush's Avatar
oldebrush
oldebrush is offline
Hi Horizonmech, and welcome to the forum.
As far as I know, and I have now a 57 and have owned in the past, a 58 and a 59, all V-8 radiators fit interchangeably. As mentioned above, the 6 cyl. rad. is not going to work for a V-8, or vice-versa.
Hope this helps you.
Aloha, Tony
Old 10-02-2013, 03:39 PM
Damifiknow's Avatar
Damifiknow
Damifiknow is offline
I got mine from NPD.
RADIATOR 8 CYLINDER | F-8005-9 | NPD
Great quality and fast delivery. Just like OEM
Old 10-02-2013, 05:06 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
57-60 272/292 mounts the same, for the F100 and F250's. Choice between three or four core, Auto or manual.
Welcome to the forum!
Good luck in your quest.
Old 10-02-2013, 05:21 PM
Horizonmech
Thanks guys, that's just what I needed to confirm, I will try a post some pics as soon as she's running and I can figure out how.....Cheers
Old 10-02-2013, 06:32 PM
Horizonmech
One more question and I will quit pestering you guy's for a while, anyone know the inlet and outlet sizes......I believe it's 1.75 top and 2" bottom....I'm narrowing it down to most likely an E-bay unit.....Thanks
Old 10-02-2013, 08:32 PM
spurredon's Avatar
spurredon
spurredon is offline
Here's a link for what you need for radiator. I bought mine there for my six cylinder, great quality. They don't give them away but once you buy one of these, you won't have to worry about it again unless someone steals it again! Ford Truck, 1957-60 V8 Radiator
Enjoy your truck.
Old 10-04-2013, 06:53 PM
Horizonmech
Jeeeze Ive NEVER tried to find a part online that had such vague fitment data and lack of dimensional size. Just Wierd to me.......Think I have the redheadded step....Everyone say's they know what I need," but oh ya really not sure"......no wonder the seller was pretty motivated ..........heh
The radiator looks like it will cost more than the whole truck.....
Old 10-04-2013, 07:37 PM
59Terry's Avatar
59Terry
59Terry is offline
I bought an alum one on Ebay. I by mistake bought the one for a GM engine swap .With the cost of sending it back,I just made the alterations myself.It works just great.
Old 10-05-2013, 11:34 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Greetings from Oregon, I just dragged home a pretty bad a## 1960 F100 4X4, 292.
After some inspections this thing (running gear) looks pretty well put together, the body has some cancer but that's a problem for another day. The problem at hand, it's been sitting in my neighbors yard for several years and someone has acquired/stolen the radiator.
Can anyone tell me if the core supports changed in 60 and made it a "stand alone" unit.
Either of these radiators can be used, as the only difference is the thickness of the core. 2WD or 4WD makes no difference, neither does A/T or M/T.
B9TT-8005-V (replaced B7C-8005-B) .. 272/292 Radiator / 23 7/8" high x 20" wide / 2" core thickness / 1957/60 F100/250 & F350 with SRW
B9TT-8005-N (replaced B7Y-8005-B) .. 272/292 Radiator / 23 7/8" high x 20" wide / 2 1/4" core thickness / 1957/60 F350 with DRW & F500/600.
COTB-16138-C (replaced B7C-16138-A) .. Radiator Support ~ 1957/60 F100/600.
Old 10-05-2013, 03:28 PM
Horizonmech
THANK YOU BILL.....that is just what the doctor ordered......I may not find those exact dimensions but it gives me a start point.....This would be so much easier if I had the old radiator in hand....sometimes I wonder WHY I get myself into these projects....anyone ever ask themselves that ??......hehe Cheers
I take it those are FORD #'s can they help me in this search, I would spec aftermarket cares not about those #'s ??
Old 10-06-2013, 03:36 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
That's cuz yer an airplane mech. We have a tendency to do that.
Welcome to the forum.
BTW how's Horizon treating you?
Quick Reply: Hi Guys, newbey with a radiator fittment question
