Radiator support spacers.
Old Oct 2, 2013 | 07:43 AM
stercorarius's Avatar
stercorarius
My bolts snapped off in the frame when I took the radiator support off. Will have to drill them out. The spacers look pretty shot too. I won't have any issues just using washers on the support will I? Don't have the time or money to get replacements from lmc.
Old Oct 2, 2013 | 08:24 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Use some 3/8" fender washers, you can get these from Lowe's or Home Depot. Fender washers have a larger OD than standard flat washers.
Old Oct 2, 2013 | 04:20 PM
Jdeshler's Avatar
Jdeshler
^x2. That's exactly what I did swapping my 66 body over to the 78.. and if the rubber mounts are too far gone you can take a circle saw and cut a few prices out of a old bed mat..
Old Oct 3, 2013 | 05:00 AM
stercorarius
What rubber mounts?
Old Oct 3, 2013 | 09:32 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Originally Posted by stercorarius
What rubber mounts?
The radiator mounts use rubber cushions on either side of the frame rail.
Old Oct 3, 2013 | 10:35 AM
crazy96863's Avatar
crazy96863
I went to the junkyard and got some from a 2x4... These were actually in good shape aside from surface rust on the exposed areas. 4x4's tend to see more mud resulting in more corrosion.
Old Oct 3, 2013 | 11:19 AM
Filthy Beast's Avatar
Filthy Beast
Or.....you could use the ever popular hockey pucks for the rubbers. Keep in mind that they are only about an inch thick, though.
xc4jokestomper
May 20, 2011 11:17 PM
ericfgs
1997 - 2003 F150
Jul 3, 2010 04:23 PM
870
Jun 2, 2007 04:33 PM
ghostflamed66
Jan 11, 2004 09:19 PM
29abone
Oct 14, 2002 11:38 AM
