Wiring questions
Old Feb 5, 2013 | 12:02 AM
scotttahoe's Avatar
scotttahoe
Wiring questions
This is very good and useful information. The last thing you want to do is get a wire that cant hold up to the job. I'm about to re wire the ignition switch and the head light switch to the new style contura v rocker switches, and going to add a bunch of lights in my 99 7.3L. I plan on using relays and fuses for the lights in the engine compartment. I have a question and probably more to come. I plan on running four rock lights under the truck, two behind the front wheel and two in front of the back wheel. Do I tie in all four lights to one wire or do I take all four wires to the relay? This may be just the start to a couple of Q's. Thanks
Old Sep 4, 2013 | 12:27 PM
ranito123's Avatar
ranito123
wire size for 52 Ford distributor??
Old Sep 5, 2013 | 05:52 PM
ranito123's Avatar
ranito123
Wire size for 52 --6 volt dist. wire ??
Old Oct 2, 2013 | 07:09 AM
Franklin2's Avatar
Franklin2
It doesn't matter, as long as the wire is big enough. Either 1 large wire or 4 smaller wires. The size wire will depend on the wattage of the lights.
Old Oct 2, 2013 | 07:11 AM
Franklin2's Avatar
Franklin2
I would use 12 gauge. Why? Because I know it's larger than it needs to be, so it should do the job. 6 volt wiring needs larger wires anyway, since voltage drop is so critical, and the amperage in the vehicle is higher because of the lower voltage.
I am not sure what the factory originally used.
Old Oct 2, 2013 | 07:19 PM
scotttahoe's Avatar
scotttahoe
Got her all finished up using 16 gauge wire with relays and fuses on a Bussmann relay and fuse block, along with the F-650 dash kit. Came out nice.
sitInHigh
Appearance & Dress-Up
Aug 19, 2013 11:39 PM
brucedog
Jan 27, 2009 09:41 PM
bigexpo
Electrical Systems/Wiring
Aug 9, 2005 11:13 PM
wera racer
Jun 18, 2005 04:03 PM
bubbin
Jan 24, 2004 05:49 PM
