I have a 1999 f250 SD and I got my lights on and now im so confused on how to wire them. I have the Recon f250 smoked lights install on my roof and I have them all installed and wired (each light is wired). I just dont have them plugged in I cant figure out where to wire them up too... anyone plz helppppp thanks guys
How to Install Roof Truck Lights | eHow I was going by this link my lights are set up to wire the ground wire to the roof somewhere (the wire is only about a foot long and connected to the harness)
0-----0-----0-×----0-----0--------------------
The (x) is the ground wire..
(0) are what connects to the lights
(----) is the wire
I can connect the ground wire to a screw that I used to screw in a clearence light on the roof. (Of course inside the truck under the roof u pull down to connection everything) can I do that? Also the one wire that I need to connect to turn them on I fed through the driver side because I was goin by what this said. Are these directions correct for my truck also? Thanks guys
