Ok. Good to know. Leads me to a couple other questions. Like if my truck has 10 spindles and the donor truck had 29, what do I do to make that work? Also, where are these "spindles" so I can count them?
Hey again HillBilly,
I did the same swap, although my original was a 4:56
I would just swap the whole smash...the Dana 60 has some tough adjustments I'm told...might want to rebuild the
drums though and redo the seals. As far as the spline issue, my old diff was the low spline count, and the new one
was a 29, so I just got a sealed conversion u-joint...easy. And they aren't "spindles", they are "splines" we are
referring to-simply count the number of splines on the differential yoke...if you need more than two hands to count
them, it's a 29 spline. (Just kidding ya Mate!)
Hey Jason. Thanks for clearing that up. Spindles v Splines.
Anyway, I just called all of the vintage places around and a few Diff shops asking for a "Conversion U-Joint" and nobody had any idea what I was talkin about. I tried to explain what I was doing and was told that I would need any sort of conversion kit for that. Saying that I should just use half of the drive shaft from each truck.
Can you tell me where you got your "Sealed Conversion U-Joint" and/or why the idea of using half the drive shaft wouldn't work.
I know this is a conversion that lots of guys do, I think I'm just making it a lot harder than it needs to be.
When you swap the whole dang thing, it is not a problem.
Anyway, I just called all of the vintage places around and a few Diff shops asking for a "Conversion U-Joint" and nobody had any idea what I was talkin about. So, what else is new?
U-joints have 4 cups, usually they're all the same size. Conversion u-joint: 2 cups are larger than the other 2.
Like this puppy that all 1965/72 F100 8' Stylesides with a two piece driveshaft came with: Ford: C5TZ-4635-F / Spicer/Dana: 210392-X / U-joint ~ 2 cups are 1310's, two cups are 1330's.
If you have two Dana 60 full floater axles set up for Ford 3/4 tons then they should be a direct bolt up. Swapping out the gears in a Dana anything is a long, complicated process for a novice machinist. The first one I did was pure torture since I had no clue what the proper steps were to take one apart leaving me with no base line.
If you have issues with the u joints not matching (I believe they should be 1350 size) then you need to get a crossover u joint. Our local Carquest has been great for having these in stock but it is staffed with local hotrodders, not your average computer jockeys. Also a driveline shop will be able to steer you in the right direction and will understand what you are trying to accomplish.
I have learned to ask the people who actually do the work rather than the kids who sell you some box with a part number on it.
1968/72 F250 2WD. If Dana 60 rear axle is from a 240/300/360: 1310 (C3AZ-4635-J = 1963/78 Galaxie/LTD / If from a 390: 1330(C4SZ-4635-A = Same as 1964/66 Thunderbird).
I'm not a kid w/a box w/a part number, I'm a 69 yr old geezer w/35 yrs of Ford parts experience armed w/the 1964/72 Ford truck parts catalog.
Thanks for the clarification. I was hoping my wording would leave some doubt.
And for the record, I in no way lump you in with the pimply faced twenty year olds in the chain stores that don't know what they are selling exactly. They are who I was referring to.
You don't need to defend yourself with me as you have helped relieve me of my ignorance on more than one occasion.
