Fuel economy computer accuracy
Old Oct 1, 2013 | 02:34 PM
catsailr's Avatar
catsailr
I bought a 2013 XLT 4X4 wiht 5.0 V8 about 3 months ago. I reset the computer when I first bought it and it shows an average of 15.7 MPG. I have also kept records of all fuel purchased and my actual mileage is 15.2 MPG.
Old Oct 1, 2013 | 06:34 PM
johndeerefarmer's Avatar
johndeerefarmer
My 2011 eco was always within .2-.3 mpg. My 2013 eco is 1 mpg or over off every tank so far
Old Oct 1, 2013 | 06:49 PM
galaxie641's Avatar
galaxie641
you are doing good if it is only a half gallon off.
Old Oct 2, 2013 | 07:11 AM
thomastl's Avatar
thomastl
My 11 Eco was very accurate (when I would fill up it was within 0.2 gallons of what the computer said I had used).
My 13 Eco is always 1.0 to 1.2 gallons low on the computer when filling up.
I am going to tell the dealership next time I am by there and see if there is anything they can do (new updated program or something) to fix it.
My guess is they purposely made it wrong in order to indicate a higher MPG on the dash which is what most people go by. That would keep down a lot of MPG complaints.
Old Oct 2, 2013 | 08:30 AM
DIYiT's Avatar
DIYiT
I have a really small sample size so far, but tank one the computer said 17.1 mpg, actual mileage was 17.2. Tank two computer said 18.1, actual mileage was 17.6.
I keep track of mileage on fuelly.com so I'll try to update this later when I have a larger sample size.
Old Oct 2, 2013 | 08:45 AM
Buck 1's Avatar
Buck 1
My '12 F-150 Lariat EcoBoost also is slightly off with the MPG computation. If you use the remote start feature, this can throw off the MPG as the truck runs for a few minutes prior to moving it, using some fuel...............
Old Oct 2, 2013 | 11:48 AM
ls973800's Avatar
ls973800
Car and driver had an article several months ago talking about this same issue. Some cars are reporting between 5 and 6 per-cent better mpg than actual mpg. Link to the article and a way (according to them) to get more accurate results from the on board sensor.
Why Your Trip Computer Isn
Old Oct 2, 2013 | 06:29 PM
galaxie641's Avatar
galaxie641
IT is funny I have never had a LOM that read low, every one has read higher than real world results. After about a year my Mustang probably did the best job, it got to almost .5mpg. My F150 stays .8-1.5 over, it varies quite a bit for just being a commuter. The work trucks are worse but they can do a lot of idling and slow moving at times which really screws up the LOM.
Blubld
Apr 28, 2022 11:02 AM
fla-gypsy
Modular V10 (6.8l)
Aug 8, 2009 05:20 AM
dynamis5
2004 - 2008 F150
21
Apr 19, 2007 07:41 PM
cjspack
May 27, 2006 09:28 AM
2004supacrewlariat
2004 - 2008 F150
Feb 29, 2004 05:54 AM
