Thumping
Old Oct 1, 2013 | 02:00 AM
lemasters f100's Avatar
lemasters f100
Thumping
Dana 60 c6 transmission. From 0-25 my truck makes a weird thumping noise. Is it u joints or am I gonna have to look into the axle?
Old Oct 1, 2013 | 10:49 AM
VocaTexas's Avatar
VocaTexas
Two wheel drive or four? Does the sound get faster/louder as speed increases? Does it seem to come from the front or rear? Does it always do it? Does it do it more on smooth or rough roads?
The only thing I can think of with the info given so far is to check the radius arm bushings if it has them. They will make a thumping sound if they are worn out.
Old Oct 1, 2013 | 12:28 PM
lemasters f100
4 wheel drive stays the same then stops at 25 all roads more common when cold
Old Oct 1, 2013 | 02:26 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
U joint usually chatter or clunk when going into gear.....Are you running bias ply tires? Have someone ride in the bed and see if they hear it back there versus in the front end.
Have you checked your shocks for being worn out and ck the rubber shock mounts.
Old Oct 1, 2013 | 04:01 PM
rogue40's Avatar
rogue40
Are you missing a cat?
Old Oct 1, 2013 | 04:40 PM
hivoltj's Avatar
hivoltj
LMAO
A thumping is almost always a tire, unless something is caught up in the drive shaft, such as a small, furry creature.
Old Oct 1, 2013 | 05:41 PM
HIO Silver's Avatar
HIO Silver
Is it speed sensitive? Meaning, the low frequency at low speed?
Lug nuts tight?
All wheel weights present?
Wheels tightened flush to the hub?
Flat spot on a tire or any tread bulge?
.. or a tire has soft spot due to separation/delamination of the inner layers. Swap 'em front to rear and see what happens.
Old Oct 1, 2013 | 08:21 PM
lemasters f100
Never had any. And not tires cause it does it with another set of 33's
Old Oct 1, 2013 | 09:31 PM
lemasters f100
Put on my glass packs and so far runs fine. Was straight piped should have thought about compression
kakashi1578
21
May 6, 2016 02:29 PM
badass truck
Mar 17, 2004 11:18 PM
bronco2angel
Bronco II
Jan 14, 2004 09:34 PM
slowfour
Mar 9, 2003 11:15 AM
fiveptO
13
Feb 16, 2003 12:40 AM
